Installed 1995 3.6 smog issue
When the CARB Referee OK'd the installation (3.6 into 1980 911) he said I needed a check engine light, which was part of the 1995 system. I have no idea about how to set this up. Help please. Thanks in advance.
Find the pin coming out of the ECU that controls the CEL, and hang a light on it. The logic is likely reverse, meaning the pin goes to ground to turn the light on. So, connect the other pin of the light to 12V.
Two wires, a light, and put it somewhere in the dash board. |
Thank you
| All times are GMT -8. The time now is 12:12 PM. |
