Door switch/warning buzzer diode?
Can anyone tell me the location of this diode?
Car is an '87 3.2. I'm troubleshooting electrical gremlins. I know it is unusual, but diodes can fail to a short (rather than the more common failure to an open condition) and that might explain some issues. Thanks in advance. http://forums.pelicanparts.com/uploa...1622256354.png |
Yes, It is in the frunk and not easy to get to....
The Warning relay is behind oil temp and fuel level instrument gauges. The diode is about 12-15 inches down the harness that connects to the relay. You should be able to get to it from the frunk The reason I know this is because I had to repair the front harness and have attached a picture showing the relay socket and the diode for you. The large circle is the diode, the small circle is the relay socket I don't have a clear picture of the diode and socket "in place" to show you....but you should bee able to find it from here. Good hunting... http://forums.pelicanparts.com/uploa...1622300946.jpg |
I did find a better picture showing the location of the warning relay/buzzer diode.
Its behind the brake master cylinder...see the pic. Alhttp://forums.pelicanparts.com/uploa...1622304489.jpg |
The information & photos you provided were a big help - Thanks!
Fyi, I discovered this is one of the infamous 911.617.108.00 diodes. |
| All times are GMT -8. The time now is 08:25 AM. |
