Rebuilding my hydraulic chain tensioners
Good morning everyone,
Does anyone know the part number of the hydraulic chain tensioner rebuild kit? Is the hydraulic chain tensioner even needed if I'm going to add the Jerry Wood upgrade Thanks David |
Use the search window above, real simple.
I have used the search function with no luck and that is why I'm asking for some help.
Although google works just fine https://www.dropbox.com/s/lfu6cgq7ydbs0bq/20210130_113307.jpg?dl=0
Don’t know if u got it. 911 105 901 01
Thanks gled49,
however these are non oil fed. If I have external oil lines don't I need oil fed? |
Thanks but the description associated with this pant number claims not for oil fed, hydraulic only
