Randy Webb's Avatar
headlight relay mounting
I have an early car (1973) and am wondering where a good place to mount the add-on headlight relays would be?
On the later cars, you can put the stock type relays into the unfilled relay mounts, but that won't work on my car...
Thanks!
Old 05-06-2003, 01:36 PM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
I have 3 extra relay mounts on my 73 but I used the icecube type relays.I think I ended up using the bolts just above and to the front and back of the fusebox.
I don't have pics of my car but where the ground is on this car is where I put one of my relays
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 05-06-2003, 01:43 PM
yep.. the fuse box area is the routine.. on my '77 I mounted them on the foreward bulkhead, close to the battery, under the hood lip
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-06-2003, 01:55 PM
nostatic's Avatar
hey, that's my car!
And that is an SC, not an early car. I used Sucro's kit with the square relays. I don't know that I've seen anyone that used the empty round relay sockets in the fuse block for the headlight relay installation.
Cool
yep.. it makes for a clean install..
dealer parts are available.. even bought the parts, but I did larger 75amp bosch.. so I need another idea to use them.....Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-06-2003, 02:00 PM
I mounted them (2 each) inside the headlight buckets behind the lights. There is plenty of room with the H4s.
Rich
2004 GT-3
1969 911E
1988 944 Turbo
1990 BMW 325i
2001 BMW Z3
Old 05-06-2003, 02:03 PM
Tim Walsh's Avatar
oohh Thanks for the picture nostatic. I pulled it right off of the server "bender"
The biggest thing is that you get components that are rated for enough amperage. I used 30amp hardware.
Tim
1973 911T
2005 VW GTI
Randy Webb's Avatar
?? The photo above says it is from a '73 but has a horizontal fuse block. The one on my '73 is vertical and sort of buried deep.
Is the photo correct?
Old 05-06-2003, 03:46 PM
nostatic's Avatar
as I said above, that is a picture of my '79
Old 05-06-2003, 04:52 PM
one of gods prototypes
bell's Avatar
i went overkill for my 100/130 euro h4's......
relay for each filiment lead........
10 ga. wire soldered to each terminal.......
these things are FREAKIN bright thanks to roninlb for the way to go
it's in the car just haven't taken pics yet, it's mounted next to the fuse box over the battery.
Brought to you by Carl's Jr.
Old 05-06-2003, 05:20 PM
Tim Walsh's Avatar
sorry if I was a little vauge. I meant to say that's not my car but where the ground for that relay is is where I put my relays are
Tim
1973 911T
2005 VW GTI
Old 05-06-2003, 05:35 PM
kcope's Avatar
I just posted pics of my upgrade here
Headlite relay upgrade, done!
Ken Copeland
70 GT6+ KC78784
70 Spit FDU84919
70 GT6+ KC81551 (Ok so I like 70s)
71 Porsche 911T
00 Chevy Pick UP
Old 05-06-2003, 06:46 PM
DJB DJB is offline
DJB's Avatar
Bell can you post a wiring diagram of the 4 relay solution pls.
Cayenne Turbo - Cargraphic Stage 2 Power kit, lowering module
997 C4 Cabriolet - Basalt Black
86 Turbo Body 911 Cab - Many Mods
Gone and Missed:
97 993TT: PSS9, CarGraphic Exhaust
Old 05-06-2003, 06:52 PM
bell's Avatar
here's a quick one i just did on photoshop.
use a multimeter or test light to ensure you connect everything properly, i'm not responsible if you use this (disclaimer )
i ran all new wiring from the relays (standard 30amp bosch) to the h4 bulbs.
i'm using narva 100/130 h4 bulbs, if you goto a high power bulb you'll need to upgrade your bulb sockets or they will melt.
Old 05-06-2003, 07:17 PM
DJB DJB is offline
DJB's Avatar
That's great thanks Bell. - Where did you get upgraded sockets are these also Narva?
Gone and Missed:
Old 05-06-2003, 07:22 PM
cary's Avatar
I just buy the factory ones, right here at Wayne & Tom's place.
I think they're about $25 each. Looks real clean when you use the holes in the fuse panel.
Not what I did. But should have.
Cary
77 Carrera RS w/3.2 #59
73 914S 2.0 AG
73 914 1.7 Driver ( daily driver, under complete rustoration )
74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor
Old 05-06-2003, 07:27 PM
bell's Avatar
i actually soldered the 10ga. to heavy spade connectors, using the sockets AND 10 guage made it impossible to adjust the lights (to tight behind housing).
ron knows where to get the sockets.......i forget
i found some at autozone but the wire was this like a 16ga. which is too thin.
cary.......i'm talking of the actuall bulb socket.....the heat generated by the HO bulb melts the socket.
Old 05-06-2003, 07:33 PM
cary's Avatar
Got you .................
Cary
73 914S 2.0 AG
Old 05-06-2003, 08:04 PM
