-   -   Sequential gearbox for 911 with 3.6 engine ??? (http://forums.pelicanparts.com/porsche-911-technical-forum/1095036-sequential-gearbox-911-3-6-engine.html)
mmasse 06-04-2021 02:48 PM
Hi
I would like to upgrade the transmission on my car, a 1976 911 with 993 3.6 engine with TPC SC. I have been running the 915 for a long time and despite all the upgrades and special care, it's simply not enough for the power of the 993 3.6 engine with a TPC supercharger.
My car is used only at the track for DE events, so I was thinking about a sequential gearbox.
I have been doing some research but couldn't find any company offering a sequential transmission (NOT SHIFTER) for the 993 engine. I contacted Quaife in the UK because I read some posts that mentioned they sell one for the 911, but they said NO.
Does anyone know if there anyone building these transmissions, or should I just surrender?
I know I could go the G50 route but honestly, I just love the idea of having a sequential tranny in that car
thanks in advance for any help
Gianni at Pelican Parts 06-04-2021 03:09 PM
It's going to cost alot of money, there are only a handful of sequential transmission manufacturers out there and they all run north of 10k. I don't think there have been any rear engine applications but Drenth Gearboxes out of the Neatherlands and Samsonas Sequential Gearboxes out of North Carolina and two transmissions I've seen on time attack cars at the local tracks out here.
Rodsrsr 06-04-2021 03:15 PM
G50 or 930 4 speed are the two most common solutions.
mmasse 06-04-2021 03:22 PM
Thank you. I will contact them. I know it will be expensive. With the money I put on all iterations on this car I could Have bought a GT3... but I still like my car more :-)
mmasse 06-04-2021 03:24 PM
I know that, thank you. I am going for the uncommon expensive option!
Matt Monson 06-04-2021 03:26 PM
We should have our 915 sequential in testing sometime later this year. We are basing off of the design of our Cup Car and Cayman gearboxes, just smaller. I don't have a firm price yet, but expect it to be around $25K or so.
http://forums.pelicanparts.com/uploa...1354740190.jpg
Regards,
Matt Monson
Guard Transmission LLC
mmasse 06-04-2021 03:47 PM
Regards,
Matt Monson
If you are looking for Beta testers, let me know!!
Bill Verburg 06-04-2021 04:56 PM
you could always buy a g97.63 from a late 997 Cup car
fitting it might be an adventure
mmasse 06-04-2021 05:03 PM
Hi Bill
Could you define adventure? Do you know if this has been done?
Mahler9th 06-04-2021 06:04 PM
The folks at Jerry Woods Enterprises Motorsports fit a sequential into a 911 with a 3.6-- I have raced against it.
Very custom and likely very expensive.
Nice to hear from Matt M. and see one of the things he is working on. We are lucky to have him and his business!
winders 06-04-2021 06:05 PM
Regards,
Matt Monson
Ok, you have piqued my interest!
fanaudical 06-04-2021 06:05 PM
Matt - 6 speed sequential gearbox in a 915 case? Very cool...
winders 06-04-2021 06:12 PM
Originally Posted by mmasse (Post 11352856)
Hi
Check with Rich Walton at Jerry Woods Enterprises. I raced against a JWE 911 with a 3.6L engine and a paddle controlled gearbox. It was not a Porsche box and it was controlled by a MoTec M130 ECU that also managed the engine (ignition, EFI, knock sensors, etc.).
Note that PCA does not allow non-Porsche transmission cases in regular race classes.
jons911 06-04-2021 06:26 PM
Hewland might be worth a look. They specifically list rear engine rear wheel drive as a category for their gearboxes. The first two I looked at were rated at I think 240 ft-lbs and 320 ft-lbs. The other upside is a wide range of gear ratios to choose from.
Matt Monson 06-04-2021 08:18 PM
Thanks guys, I have testing set up already.
The build JWE did uses a Holinger proprietary transaxle . And it was done all with with paddle shifters because the client had lost use of his clutch foot. It’s a very trick set up Jerry did.
Matt Monson 06-04-2021 08:27 PM
Originally Posted by mmasse (Post 11352958)
Hi Bill
This kind of adventure.
https://rennlist.com/forums/porsche-cup-cars/704285-69-gt3-cup.html
Mahler9th 06-05-2021 08:49 AM
"The build JWE did uses a Holinger proprietary transaxle . And it was done all with with paddle shifters because the client had lost use of his clutch foot. It’s a very trick set up Jerry did."
Yes. Their client is a great driver and a great person. The car has a lot of very custom features.
See, e.g., https://www.facebook.com/JerryWoodsEnterprises/posts/congratulations-to-mike-gaulke-and-thomas-merrill-for-their-victory-at-the-class/1943651092318870/
Pretty sure that Kevin Buckler/Racer's Group fit up a Hewland with straight cut gears in an air-cooled back in their early IMSA days... but it wouldn't have had paddles.
Arlo911 06-05-2021 09:15 AM
There´s a guy in Holland with a sequential gearbox in a street driven 964 Carrera 4. Don´t know if that would be adaptable to your car though. His website is www.raphautomotive.com
mmasse 06-05-2021 07:46 PM
Thank you. I just sent and email to him and Holinger. Lets see if get lucky!!
Raceboy 06-05-2021 11:20 PM
Samsonas is actually Lithuanian company and is very widespread around this part of the world, makes quality parts and is actually quite reasonably priced. Definitely worth checking them.
mmasse 06-06-2021 07:04 AM
Thank you. Already contacted them. Waiting for a response. I will post once they reply
3rd_gear_Ted 06-06-2021 09:38 AM
Just some SoCal Kudos for taking the fight with the H2O pumpers on the track to the next level.
Push, push, push, pace pace pace :D
Tbone1209 11-04-2021 05:35 AM
Any updates?
mmasse 11-04-2021 06:38 AM
Originally Posted by Tbone1209 (Post 11508047)
Any updates?
Yes, unfortunately they don't have anything for my application yet!
911SauCy 11-04-2021 09:07 AM
I do believe Tuthill Porsche has built an aircooled rally car or two with a sequential. Might be worth looking them up and reaching out
Dan J 11-04-2021 05:34 PM
The ricardo sequential from a 991/1 cup is very compact ( and very good) I have a few and looking
at them next to a 915 they are very similar sized much smaller (and better) then the g50/holinger
unit from a 997 cup
It would be a complicated and expensive installation but it's a great trans
Matt are you making gears yet?
sithot 12-08-2021 04:30 AM
914-6 with 6 Speed Sequential
I'll take one.
https://www.youtube.com/watch?v=DmG4hWCjxfQ
Matt Monson 12-08-2021 05:16 AM
Life goals
sithot 12-08-2021 06:06 AM
I'm not getting any younger...;)
jmz 12-08-2021 08:59 AM
Following. ...at the rate I have my racing 915 rebuilt this might be a less expensive option!
Geneman 12-08-2021 10:46 AM
ME TOO. JMZ.. WTF! is it me or do these gearboxes just suck for racing. no matter how " gentle, slow etc " i shift. including good heel toe, i am getting 3-4 EVENTS out of 1 rebuild ( professionally done). not sustainable.
Clay Perrine 12-08-2021 12:12 PM
Put a 6 speed out of a water cooled 911 in it. You get a way better transmission, hydraulic clutch and a cable shifter.
Clay Perrine
Geneman 12-08-2021 12:22 PM
:mad:I had 2 G50-01 race gearboxes, with cooling plumbing and short geared .... sold them thinking the 915 would be OK.....:mad::rolleyes:
I do not think any of the 6 speeds from a water cooled car will fit without extensive structural work... but the hydraulics and cables are mighty tempting at this point......
Everytime i vent To Dan Jacobs ( Hairy Dog Garage, CT) about the 915s he tells me in his oh so gentle manner; GET RID OF THOSE FOCKING THINGS!!
Clay Perrine 12-08-2021 12:38 PM
I have a 914 with a 964 motor and a g86-21 transmission from a 2006 Cayman S in it.
The transmission handles the power from the 4.0L 964 motor with no issues, and it shifts great.
I don't know how hard it would be to put one in a 911, but nothing is impossible.
Clay
winders 12-08-2021 01:20 PM
Those big G50 race gearboxes are great except that they are much less efficient than a 915.
Matt Monson 12-08-2021 02:27 PM
Clay
Who is making an adapter plate and flywheel for that conversion?
sc 12-08-2021 05:21 PM
Found this site....
https://www.transaxleengineering.com/
VW and Porsche type transaxles...some sequential for VW's....maybe it will work for Porsches as well?...Hmmmm!
Geneman 12-09-2021 10:39 AM
sc.... some amazing stuff on that site... really beefy off-road TAs ... they do not even list the prices for the Porsche boxes.. yikes!
Antonov 12-09-2021 12:18 PM
That car is seriously cool!
Originally Posted by sithot (Post 11540684)
winders 12-09-2021 12:33 PM
I get a full season out of my 915 and that is with ~430 HP 3.6L bolted to it. What are you doing to your box?
