-   -   Run for a short time and died (http://forums.pelicanparts.com/porsche-911-technical-forum/1095118-run-short-time-died.html)
yuth 06-05-2021 05:39 PM
Hello
My 79 sc has been sitting in a garage for some time. Battery was dried out. I recharged the battery. Car started right up. After about 5 mins . Engine stopped. I turned the ignition switch, no power to the car. All electrical system shut down. Any idea ? Thank you
HarryD 06-06-2021 12:41 PM
Is your battery flat again?
proporsche 06-06-2021 01:55 PM
check your connection you just put on your battery..you could have bad ground or even those red wires on plus-side loose
Ivan
gomezoneill 06-06-2021 02:36 PM
After a storage battery goes dry it most likely wont hold a charge.
yuth 06-06-2021 03:59 PM
Ivan
Found loose wires on plus side. Ordered a new 925 from Amazon. Still waiting on a terminal post. Thank you guys. Always helpful here !http://forums.pelicanparts.com/uploa...1623020217.jpg
http://forums.pelicanparts.com/uploa...1623020330.jpg
proporsche 06-06-2021 04:08 PM
u r welcome;-)
Ivan
Bill Douglas 06-06-2021 04:27 PM
I don't think that green wire should be attached.
Unless someone used green because they didn't have another color. I'd still follow it and see where it goes.
yuth 06-07-2021 04:34 AM
You mean I should disconnect it ?
proporsche 06-07-2021 07:49 AM
what he means is..the green wire is not an original part of the el.harness but in your case you should trace it what is it powering....most likely radio...? take picture where it leads and we will tell you ..
Ivan
yuth 06-09-2021 05:39 AM
Ivan
It goes back to the passenger side.
yuth 06-09-2021 05:45 AM
img]http://forums.pelicanparts.com/uploads26/11F6BC25_B0B2_4F3F_9CEF_93A8CC6763231623242685.jpg[/img]
proporsche 06-09-2021 06:13 AM
to insert a picture go to the advance and there is a blue link to click on and insert pic
Ivan
HarryD 06-09-2021 01:09 PM
Originally Posted by yuth (Post 11356983)
Fixed, it was missing a bracket.
You need to see where it goes on the other side.
proporsche 06-09-2021 01:39 PM
good job Harry..still thinking it goes to the radio
Ivan
