Home of the Whopper
Aftermarket pedal asembly
I need to replace the M/C and pedal assembly in a 73.5T budget track car. I'm looking at my options and it looks like an aftermarket Tilton on Wilwood dual pedal assembly with the master cylinders will only be a little more expensive then factory parts. So, my question is.....
Floor mounted, swing mounted, reverse mounted, firewall mounted, etc...??? Does anybody have experience with any of these? Which one will be the easiest to fit into a 73.5T? Can the hydraulic clutch be fitted to the 915? I plan on using Carrera front brakes, should I go with a larger master cylinder? Thanks! BK Last edited by BK911; 05-09-2003 at 09:47 AM.. |
