Help replacing this brake hose?
I’ve gone through life so far not having done anything more than brake pads, somehow. But lately I’ve noticed calipers sticking and other issues so I feel like it’s just time for a full brake rebuild. I have new - rotors, pads, rebuilt calipers, as brake lines, good brake fluid, parking boots, and more from our host. I’m just about ready to tear into it but I noticed this:
http://forums.pelicanparts.com/uploa...1623726834.jpg Figure I should tackle this as well. Questions I have if anyone is willing to answer them: 1. Do our hosts sell this? I didn’t see it in the brake hose/line section. 2. Is it recommended to upgrade to some other hose that won’t have this same seep issue or is it a fairly reliable part that just failed due to time? 3. Can I proceed with installing everything else? Rotors, pads, lines, etc? I can wait for this part to come in and install it later, is that an issue? 4. I figure brake fluid will poor out of I disconnect this hose. What’s the trick here? Or do I just drain all the fluid, remove hose, replace all fluid? Remember it’s my first time doing a brake flush as well so I am just trying to be safe. 5. Anything else I need to know?? Thanks to anyone in advance! |
Find a Turkey baster thing in the kitchen .
Suck all the fluid out of the reservoir first . Replace hose , and replenish fluid , then put turkey baster back in kitchen . You’ll probobly get in trouble for this a couple of days before thanksgiving .... |
Anything important to note about the hose install? Or just tear it out and shove one in its place? |
You might have to heat the hose in to get it pliable enough to slip over the barbs .
Apart from that it’s a simple job . Do not use hot water to heat , as you would on many other hoses , as it will migrate into your brake system . Go to the bathroom and look for a hairdryer . You can use this to gently heat the hose . You might get in trouble for this tomorrow morning ... |
| All times are GMT -8. The time now is 10:16 PM. |
