![]() Since the CIS Frequency Valve assy is now over $600, I was asked if I could build a substitute using a standard Bosch Fuel Injector. Here is what I am working on presently.... ![]() It is a housing to retain this standard Bosch Fuel Injector along with Injector End caps that are sealed by the injector O-Ring and allow Fuel Hose to tie in to the standard fuel system. This will provide additional fuel when under Boost or heavy load/acceleration. Of course hoses/lines will be made up to match whatever system this will tie in with. I welcome comments as we proceed with this project. Len.Cummings at verizon.net
![]() This has taken much longer than expected, as backups at the Machine shop and at the platers kept me in limbo, but now I have the Beta Test piece done..... ![]() Andial was getting $700 for this back then. Cost for this one is about 1/2. This should also work as a frequency valve replacement, and we should have one for the 911 SC configuration soon. Please email me, len.cummings at verizon.net if interested. Thanks for looking. Len
Excellent work Len.
John |
Wow that's awesome!
