-   -   Rear Swaybar Drop Links (http://forums.pelicanparts.com/porsche-911-technical-forum/1096143-rear-swaybar-drop-links.html)
Steam Driver 06-19-2021 12:51 PM
I have a set of Tarett Engineerings rear sway bar links to install on my SC. However I have what may be a stupid question.
What is the function of the offset hole in the metal bushing? Obviously the offset is there as an adjustment function but for what and why? It doesn't seem to have enough offset to have much effect. Is this a way to offset preload on the bar?
Any suggestions will be appreciated.
http://forums.pelicanparts.com/uploa...1624132230.JPG
dannobee 06-19-2021 01:29 PM
Rear camber adjustment. Or toe. One or the other.
Steam Driver 06-19-2021 03:44 PM
No. The sway bar has nothing to do with either of those.
winders 06-19-2021 04:00 PM
Sure it does....if you mount the drop link to the spring plate like many do today.
winders 06-19-2021 04:08 PM
See here:
http://forums.pelicanparts.com/porsche-911-technical-forum/670046-tarret-drop-links-install.html
http://forums.pelicanparts.com/porsche-911-technical-forum/473810-tarret-rear-sway-bar-drop-link-issue.html
jjeffries 06-19-2021 04:30 PM
Same on a 944. Standard Porsche design of the era, right?
John
garment 06-19-2021 05:43 PM
I installed these earlier this month. You’ll need to install the links finger tight on the bolts, and then rotate the spacer in such a way that the upper ball joint can rotate back and forth and doesn’t bind as the sway travels under load. Easier seen than explained.
Good luck!
911pcars 06-19-2021 06:29 PM
As I mentioned in the referenced link, there needs to be rotational space on both sides of the spherical bearing. If none or very little, the joint cannot freely transmit angular movement as needed. The available space may not accommodate a rod end. In that case, an alternate method has to be employed (e.g. rubber bushing).
Sherwood
Mahler9th 06-19-2021 08:40 PM
Not much benefit from adjustable drop links on stockish street-use-only cars.
As others have pointed out, the eccentric facilitates spring plate mounting. For some cars, trailing arm mounting is possible.
Removing ARB pre-load requires car to be at proper weight, including in driver's seat. The rest is straightforward.
Eccentric gadgets for aftermarket rear ARB drop links do not hold as well as the "locking" scheme I described in previous threads. Of course that scheme holds toe in place an eliminates the need for a custom eccentric of any kind.
Again, I have found the Puhn book to be the best reference... added bonus: the cool car on the front cover was likely raced professionally out of Mountain View, California.
Steam Driver 06-20-2021 05:16 AM
Thanks everybody.
911pcars 06-21-2021 08:35 PM
Fixed length drop links precludes removing preload from the sway bar due to whatever the case with the chassis. A preloaded sway bar (at a standstill) affects corner balance if that's an issue of concern for good handling.
Sherwood
Walt Fricke 06-26-2021 10:03 PM
I don't believe Porsche ever used the rear alignment hardware for sway bar attachment. For sure not on 911s. That was an aftermarket approach starting, perhaps, with Automotion's bars.
winders 06-26-2021 11:21 PM
Yes, of course Mahler9th knows that.
The important words to notice are "stockish street-use-only cars". Obviously Porsche didn't care about preload issues with "stockish street-use-only cars" since none (I think it is none....but certainly virtually none) of their air-cooled Porsche 911 cars with sway bars had adjustable drop links.
How many air-cooled Porsche 911 "stockish street-use-only cars" ever get corner balanced?
chrismorse 06-27-2021 07:29 AM
making things adjustable
As long as i was making things adjustable, i decided to try drilling the stock (85) 18 mm rear bar flat sections to get a little adjustability out of the rear bar when using the adjustable drop links.
The bar is harder than the hinges of hell, so cobalt bits are a must. This is a fairly small change in resistance, less than a bar size change
I chose the Elephant ones because they had a boot on each end to keep most of the road dirt/water out of the joint. The adjustable spring plate sports a camber max from elephant also, I have heard it is not a huge improvement, but it helps.
It looks like when getting an alignment, rotating the cam or toe eccentric, (which ever has the drop link)will also load the drop link, so before alignment, it would help to loosen/disconnect the top link bolt. Post alignment, the drop link can be adjusted for 0 preload and reinstalled. Probably best to have the alignment tech do this as he will have the car on a (Hopefully) flat alignment surface..http://forums.pelicanparts.com/uploa...1624804110.JPG
dannobee 06-27-2021 01:02 PM
I know that from first hand experience, too! Once it's been tempered, it's just like a spring.
You need to do the math on the changes in the arm moment. Each hole can be a big difference in bar stiffness. I would bet that a half inch movement of the hole will make a bigger change in stiffness than a 1mm change in bar diameter.
Walt Fricke 06-27-2021 04:00 PM
Right - the change between hole 1 (front hole) and 2 (center) is much larger than the change between 2 and 3, even though they are equally spaced. There is an exponent in the formula. As a practical matter, if you start with the rear hole, and decide you have too much push, so move to the center, but conclude that though it is better, why not try the front hole, you might find you are now too loose (this all being without adjusting the front sways, if they are adjustable).
chrismorse 06-27-2021 04:10 PM
Effect of drilling adjustment holes in rear bar.
Check this out Danno; see if i slipped a digit or just had a senior moment, further degraded by cerveza and using a ruler for on car measurements.
Original drop link mounting hole is roughly 6.1 inches to centerline of antiroll bar. First hole is roughly 5.23 inches from bar CL, so 6.1/5.23 = 1.17, for a 17% leverage advantage.
Hole #3 is 4.35 from bar cl, so 6.1/4.35 = 1.40, or a 40% increase in bar effectiveness.
Keeping the bar length the same and only changing the diameter, we can use the Diameter to the 4th power for a relative comparison, (also keeping the lever arm the same).
18x18x18x18 = 105K
19x19x19x19 = 130K so, 130/105 = 24% stronger than 18mm bar
20x20x20x20 = 160K so, 160/105 = 52% improvement over 18mm bar.
So, if i've got this right hole #1 is stock
Hole #2 is a 17& improvement and
Hole #3 is a 40% bump in effectiveness, somewhere between the 19 and 20 mm bar.
Praying for guidance from the cognoscenti,
chris
p.s. I have heard a vicious unsubstantiated rumor that a HD Polyurethane bar chassis mount will, by reduced compliance, increase the effectiveness of the bar by a one size increase.
sorry for the off topic side track, (but it was close :-)
dannobee 06-27-2021 09:39 PM
Recheck your math. Just doing a back of the napkin calculations, changing the arm length from 6.1 to 5.23 makes the bar about 40% stiffer and changing the arm to 4.35 will double the stiffness. But again, I'd need to know the exact measurements on the bar (distance between the bends, exact diameter).
Changing the arm from 6.1 inches to 4.35 inches would in effect be the same as changing the bar diameter from 18mm to 22mm. FWIW.
Now, how does this all fit together? It is one data point when computing the front roll couple. You'd compute front roll couple by calculating wheel rates and adding bar stiffness (don't forget motion ratios) to each end of the car, and throw in the rear weight and hp as variables. Higher hp cars require higher front roll couple, for instance. A miata might handle best at 50% front roll couple but a high hp Nextel Cup car might want 92% front roll couple, even with the same f/r weight distribution.
winders 06-27-2021 10:47 PM
Ah, good ol' roll couple distribution (RCD).
I don't think most people that install sway bars on their 911 cars have any idea as to the actual front and rear wheel rates. Most certainly they don't know how much the sway bars effect the wheel rates in roll. There is no way in hell they have any idea what their actual RCD is or what it should be if they did.
Even if you did know all the wheel rates, the sway bar rates, and the weight distribution of the car, there are a bunch of other variables that make calculating the "ideal" RCD problematic. Here is a short list that I could come up with off the top of my head:
Tire choice
Tire pressures
Camber settings
Toe settings
Aerodynamics
Ride height/Rake
Moment of Inertia
Driver preferences
I am sure there are many more.
Aerodynamics is probably the variable that can make the biggest difference.
We change roll couple distribution to affect the handling balance of the car. On the most basic level, the average 911 driver doesn't need to know anything about wheel rates or how much the installed sway bars add to those rates in roll. The driver just needs to know if his car has too much understeer, too much oversteer, or is just right. Depending on the car and the situation, you may need to adjust aero instead of RCD or both the aero and RCD to affect the correct balance change.
Air-cooled 911s have been around for a long time and are generally well understood. For just about any model with just about any normal torsion bar combination, the sway bar choices are also well understood. If you call up Tarett or JWE and tell them what your car is and how you plan on using it, odds are they know exactly what sway bar sizes will work well.
Walt Fricke 06-27-2021 11:03 PM
VanValkenburg gives the formula for sway bars. As a practical matter, the bar diameter is what it is, the constant determining the bar's deformation is fixed, and the bar's length is fixed. The only variable at the track is the arm length. And that is a "length squared" term. So you can't just use teeter totter lever calculations to determine the effect of changing the arm length.
As a practical matter, all you need to know is that the changes are non-linear, because you have only three holes, and you will want to experiment with all three of them to see which works best for the rest of your setup. In bars with slider adjustments you just keep moving one direction or the other to optimize.
GaryR 06-28-2021 03:21 AM
Didn't see it mentioned, but if you increase the sway bar size (or possibly change the OEM bars rigidity by adding holes inward) you had better address the sway bar mounts weakness by either reinforcing it or replacing it outright.
Mahler9th 06-28-2021 09:50 AM
In my experience (racing), you do not necessarily need to reinforce or replace factory ARB mounts when you employ a stiffer-than-stock factory or aftermarket bar.
My car is a '75, and I have used a '75 bar, a very large diameter 930 bar, and right now have the excellent Tarett set up. My mounts have never had an issue.
My car is a 2000 pound race car with coilovers, and the bulk of the wheel rate out back is created by the springs.
So of course if mounts are compromised they should likely be addressed, but in my experience the answer for every other situation is "it depends."
In the past 30 years I have seen it be pretty common for folks to employ a stiffer-than-stock factory or aftermarket bar to increase rear wheel rate without making a change to t-bars, since the work is so much easier/bolt on. That type of set up may theoretically put more strain on the factory ARB mounts.
I have had extensive conversations with the designers/developers of all of these rear ARBs:
Charlie S. (Charlie Bars)
Dwight M. (Weltmeister)
El CW and Jerry W. (JWE/SRP)
Ira R. (Tarett)
All great folks and great products.
I have also had many conversations with enthusiasts that have not taken the time to understand the rear suspension system to ensure they are making the optimal choices-- not only for ARB alternatives, but also for things like maintenance.
I have a friend I am currently helping out with a beautiful '74... we are going through the thing and getting it mildly set up.
The standard '74 rear ARB is used, and when we went to disconnect it to measure CB, it became instantly clear that his factory rear ARB drop link bushings have so much stiction that no doubt handling has been affected. So we are addressing that.
It can be very helpful to make sure all that stuff can move freely.
In any case, it seems like the OP's question(s) have been answered.
Walt Fricke 06-30-2021 09:05 PM
If you have a welder, it is pretty easy to cut some steel to size and weld it on, boxing in the ARB mounts. Plenty stiff. I lost a mount long ago due to a rock which had fallen on the mountain highway while I was driving to a DE in Aspen/Woody Creek. Ran over the rock, and it broke a mount loose (which I discovered the next day at some point while looking under the car or changing tires or something). Muffler shop welded things back on, and later I boxed them in. Still holding.
chrismorse 07-01-2021 07:19 AM
one simple example,74 coupe, totally stock,same/only calm driverr
My dad ordered the car with the carrera bar option 20/28mm. He was an engineer who appreciated, but never worked on his car. No competition, no canyon carving, just sane transportation.
at some point, the rear bar mount fatigued and broke off. His shop probably talked to him about his driving style and they concluded he would be fine with no rear bar, so they removed the rear bar. He drove it that way for many years, untill he passed the car to me.
Mike, I see your point that most hotrodders/racers will up the T bar, (or coils), therefore the RARB is "less" stressed, but there have been a fair number of reported failures, of stock bar mounts. I'm happy with the Wevo fix.
