-   -   Jenvey ITB's and Airbox Anyone? (http://forums.pelicanparts.com/porsche-911-technical-forum/1096251-jenvey-itbs-airbox-anyone.html)
Fredie 06-21-2021 11:18 AM
Hello,
Has anyone fashioned or found a solution for an airbox for the Jenvey individual throttle bodies? Other than the usual bolt on a GT3 intake complication on top.
I love the way they sound but for a long drive they are a bit loud.
An airbox should dampen the intake noise quite a bit while still retaining the trumpets.
I look forward to hearing some suggestions.
Regards, Steve
http://forums.pelicanparts.com/uploa...1624299110.jpg
Classic 911 06-21-2021 11:22 AM
Following
phelix 06-21-2021 01:06 PM
I have ITBs with ITG filters on a pretty extreme 3.5 twin plug engine and induction noise is surprisingly low. Exhaust is quite quiet because of a rather large dp motorsport muffler.
Short answer is change your muffler.
winders 06-21-2021 01:18 PM
Fredie,
The best solution is to put 996 GT3 intakes on top of the ITBs. I am pretty sure that Rothsport has done this Jenvey ITBs. It would look like this:
http://forums.pelicanparts.com/uploa...1377358466.jpg
The ability to do this requires an ECU that could control a flapper solenoid. Well, I guess you could use an RPM switch too. This setup gives you better midrange torque and supposedly does not hurt top end power.
Fredie 06-21-2021 02:40 PM
Agreed on the muffler. It is a bit loud as well.
I see Jenvey offers an air box to fit the base plates I have. I was hoping someone may have tried them with a cone filter retaining the velocity stacks/trumpets inside. Or other concepts similar as such.
I like the idea of the long runners and etc.. of GT3 intake but it seems like a lot of fiddling and extra weight for perhaps minimal gain.
My engine has plenty of low mid and top charge.
winders 06-21-2021 03:57 PM
I was trying to help you get quieter induction...I guess that is not what you really wanted....quieter induction with more midrange torque. I'll keep my ideas to myself......
Fredie 06-21-2021 05:26 PM
I did not mean to shoot your ideas down. It is a proven solution. I was just wanting to find a different solution.
I appreciate your input.
Regards
