daltvater's Avatar
Cage for Coilovers? (Pics)
Experts,
I'm at a cross roads and sick of reading conflicting information. Hoping someone has some information that I cannot find.
1979 SC, 3.6, coilovers, running Nankang AR-1's (not slicks)
The car had a weld in full cage but like an idiot I had the front half removed (before I got into extensive track time)
The car is flexing something fierce at the moment. You can feel it twisting and hear it popping and creaking under load.
My question, if I weld in the front half cage will I gain any structural rigidity to benefit the front suspension? Half the Porsche experts out here in NZ are saying yes, the other half saying the front cage would only be for safety purposes.
2nd question based on the 1st. Do I need to tie a front cage through the dash into the front struts to achieve the rigidity I'm looking for?
All sort of threads on the cage subject but I can't find data only opinions.
Thanks!
Dan
Old 06-13-2021, 09:38 PM
porsher
aston@ultrasw.c's Avatar
In my experience a six point cage stiffened up the tub significantly.
ie A, B and C pillars only: not including the front shock towers
How do I know?
Well at my home track the front suspension started bottoming out after the cage was installed
I concluded that the body flex was absorbing some energy which was not the case after the cage went in.
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 06-14-2021, 12:04 PM
Jeff Alton's Avatar
Your front half cage with stiffen the entire chassis significantly.
Cheers
www.turn3autosport.com
Old 06-14-2021, 07:24 PM
Evan Fullerton's Avatar
I’m not saying you need to do this........ but I put a bit of steel in the front of my car..... the chassis is quite stiff now.
Old 06-14-2021, 07:45 PM
Old 06-14-2021, 07:53 PM
Mine is similar , tied into the upper shock towers and rear front arm mounts .
Are you also tied into the front A-arm mounts Evan ?
Old 06-14-2021, 08:16 PM
Racer
winders's Avatar
This seems to work great for my race car......
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 06-14-2021, 08:45 PM
Scott
I asked for pics before but never got a reply .
Is yours tied in all the way from front A-arm mounts to rear engine mounts ?
Old 06-14-2021, 08:51 PM
Ian, while I was having the front suspension pan replaced, a plate that pickup up the 3 nut inserts was welded in with the stub tube that ties into the gas tank cradle. The X behind the gas tank picks up the nut inserts at the rear. The X in the rear was an afterthought when hearing some of the rally guys on big impact had moved the steering rack crossmember up.
I’m in the process of tying the 935 camber boxes in the rear into the cage in a similar fashion. The only part of my suspension not triangulated into the cage will be the spring plate pivots. That’s the 1pt. to keep it from being classified as a tube frame car.
Old 06-14-2021, 09:18 PM
Thanks for the info Evan .
I might yet still have to find time to come look at your car , just to see what it is all about .
I think mine is/was maybe not far from being full-space-frame , but it was the engine mounts ..
Quite a bit has been removed since then , but it would be interesting for me to see what should be left and what can be removed once the restoration starts to make it back into to a road car .
This is just for my knowledge and entertainment though , as I’d rather pay an expert than claim to be one
Old 06-14-2021, 09:29 PM
Racer
winders's Avatar
Scott
I am sorry. I must not have seen the request or forgot to respond.....
Yes, it is tied from the front to the back:
Scott Winders
PCA GT3 #3
Old 06-14-2021, 10:30 PM
Racer
winders's Avatar
Oh, engine mounts are solid and there is no rear chassis crossmember:
Scott Winders
PCA GT3 #3
Old 06-14-2021, 10:35 PM
Thanks for the info Scott .
Old 06-16-2021, 08:53 AM
175K911's Avatar
My cage is tied to the front and rear strut towers, from all the experts I'd consulted 15+ years ago this is a necessity with coilovers. Especially in the front, those shock towers were never designed to take the forces of 400+ pound springs. I bet everything up front is flexing. I made sure my cage was tied to all the appropriate places front and rear before ever going to coilovers.
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 06-16-2021, 06:20 PM
daltvater's Avatar
This thread is what I needed. Going to give the shop these pictures and see what they can do. Didn't want to pull the gas tank but maybe I will to tie the cage into the front.
I've already created a 12 inch crack in the wheel well below the strut mounts. Strut mounts held but the tub didn't. The crack is in place you would never have guessed.
I'll post pics when the cage is done! Thanks for the help!
Old 06-21-2021, 03:49 PM
