47silver's Avatar
Mfi stack cold start fittings
I noticed that some of the plastic fittings that are connected to the velocity stacks are loose. These are the small fittings that are only used during a cold start and use 3mm hoses and the special compressed type hose clamps.
Although i do not use the cold start mechanism i suspect that i am getting air intrusion at those locations.
Would anyone know what type of sealant or glue should be used on these fittings?
Old 05-12-2022, 05:22 PM
I don’t think there’s one right answer (haven’t seen anything from Porsche on this) but I would recommend reinzosil. It’s not permanent, will blend in, and should seal.
Daniel
it's not leaking....it's just marking it's territory
Old 05-12-2022, 06:04 PM
47silver's Avatar
Thank you.
Old 05-12-2022, 06:39 PM
(man/dude)
Jonny042's Avatar
Since they are above the throttle plates, any air intrusion at that point will not be a vacuum leak and would not affect the way the car runs.
It would be unfiltered air, though. I am not using the cold start nozzles on my 3.2 MFI and I used rubber hole plugs to block off the holes and removed the nozzles entirely.
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 05-12-2022, 06:44 PM
47silver's Avatar
That plugging may be a better approach
Old 05-12-2022, 07:24 PM
