-   -   nditiz1’s classic retrofit electrocool installation questions and comments (http://forums.pelicanparts.com/porsche-911-technical-forum/1096376-nditiz1-s-classic-retrofit-electrocool-installation-questions-comments.html)
mike sampsel 03-31-2022 01:43 PM
Originally Posted by Nditiz1 (Post 11373070)
Thanks Jonny - I attached it how Pat attached his.
I began to work on the driver side and was feeling the pain others have stated about "a tight fit." I managed to tear the pipe under it. I used some flex piping that was about 58mm wide, slid it inside of the oem duct to create a flex coupler. The real test will be getting a 60mm hose over the T with all the wires and ground post right next to it.
http://live.staticflickr.com/65535/5...8e6cdacc_c.jpg
Any update on how you addressed the inside T fitting (on drivers side) with the wiring harness interfering? Looks like my hose will be crushed in half or so unless I figure out how to move the wires better than so far. Thinking of trimming this side of the T also. Your thoughts would be appreciated.
http://forums.pelicanparts.com/uploa...1648762869.jpg
Showdown 03-31-2022 02:34 PM
I had the same issue- here’s my fix: I split the harness and ran half of the wires in the crotch of the T and half between the T and outer wall of the tub. https://uploads.tapatalk-cdn.com/202...15af3b6a8b.jpg
Nditiz1 04-01-2022 05:24 PM
I dont remember having to move any wires.
Here is a video I took last year. Also, my hose gets a little crushed on the driver's side as well. The SCEET hose holds up better, but also less forgiving.
Vid
https://youtu.be/5AOfSk0faQo
Showdown 04-01-2022 06:12 PM
I spent the better part of an hour trying to fit the hose with the wiring harness in place and came to the conclusion they for my car it just wasn’t going to work. Moving some of the wires made it all of 10 mins before everything was hooked up.
There was also no way to not somewhat crush the hose with the gas shocks installed and I didn’t want to go with a hood prop. That hose is just hot air from the engine bay so I wasn’t too concerned about deforming the hose. If it were air out from the blower they would be a different story but luckily for me none of the output hoses got deformed.
hannu_911 04-03-2022 12:14 PM
Here is a picture how I re-arranged the wiring harness in my SC
http://forums.pelicanparts.com/uploa...1649016823.jpg
