dual plug dist trigger
Looking for info on 3.6 lt twin plug dist to be installed into an earlier engine. Has anyone or does someone sell a kit that can be installed into the dist or externally mounted as a triggering devise for the CDI,MSD. As in transplanting the guts from a 3.0sc dist into a 3.6 dist. or a cam or crank sensor that could fire a Bosch 993 ignition unit and coil set up ?
Old 06-24-2021, 01:47 PM
twin plug
I have a 3.6 dizzy with the magnetic pickup from an SC with new drive belt I was just about to list for sale.You need the brass drive gear from a 3.2 or 3.6 on the crankshaft to work.$775.00 SHIPPED CONUS.You use MSD or stock CD.Ciao Fred
Old 06-24-2021, 02:33 PM
