What would you do in this situation? (Mechanic)
I found a shop and visited them for a set of shocks and some other work. While there, the tech pointed out that my bushings are all worn. We set up a full suspension rebuild. Ordered the parts to his shop, he said he'd look through them and let me know if I had everything, then I could drop the car off.
That was in October. All parts were delivered on November 3. He's been swamped with employees out and general covid, but this is going on four months. I've called a number of times, and I'm told that he'll call me back, but I haven't received a call. I just want to know whether all the parts he needs for the job are in, and whether he has the capacity to do this work. What would you do at this point? Should I just pull the parts? Not sure why it's so difficult to find a good shop in this area. Let me know if this isn't the correct forum.
89 Carrera 3.4 "There is a right way to go around a corner - it's called the line." -- PCA DE speaker bryteside.com - good things happen. |
Slow old car
By now, I'd probably arrange to pick up the parts, assuming you're the one who paid for them.
Mike 1980 911 SC 3.1 Coupe // 1986 VW Vanagon Syncro EJ22 // 2015 Macan Turbo // 2017 i3 REX |
drop by - ask for a firm date. get a feel for what's going on.
it's been a tough go, all around - a special case scenario. not satisfied/in a hurry? go elsewhere. |
Registered Minimalist
Pick everything up today.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
+1
Plenty of shops in NY/CT that would treat you much better.
1979 930 |
Went through something similar. Has he begun disassembling the car? If he has, then it’s more nuanced and you’re partnering him through it. Would help to stop by in person and agree a timeline with several milestones you can hold him accountable to. The mini-milestones will keep the pressure on simmer and also help you realize just how off track you are.
If he’s not calling you back and not being communicative, and the car is still driveable, I wouldn’t go further. He may be having a tough time, but ought to let his customers know (in the hope they support him through it). Collect the parts and find another shop. |
1988 Carrera
For the last four months he has been doing work on other cars, not yours. Would pi$$ me off. You were put on the back burner. I would see if I could get my car/stuff back. Then bad mouth the $hit out of his business. But that's just me.
88' Carrera 79' SC gone (lost to Katrina) 75' Targa gone 72'914 gone 72' 914 gone too |
To clarify, the car is in my possession. I would not have left it with him for four months. I ordered the parts from pelican to his shop, per his request. Something like $3k worth of suspension components.
I had wanted him to do the work as I'd heard good things. I'd have been fine if he'd simply called me back, told me he was still swamped, apologized for the delay, and told me he needed more time. I wasn't in a rush at the time, and communicated as much to him. But I've called every other week for a few months now, and I haven't gotten so much as a return call. My schedule is tightening and I have no idea whether he has all the correct parts, or even whether he's capable of doing the work. I guess the answer to the second question is clearly no. Agreed - time to pick up the parts. This sucks.
Any suggestions?
Daniel Jacobs LLC in southbury CT
Musante Motorsports, South Windsor, CT Speedsport in Danbury CT ( no direct experience but I have seen them mentioned by others) Most of these places will pick up and drop off your car in trailer (if needed).
1979 930 |
Titanium User
Clear your pm and I’ll send you some local places
Buy some Titanium Lug Nuts! http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1032311-fs-titanium-lug-nuts-studs-v2-0-a.html ig: @ti_porsche_products |
Cleared. Thanks.
dg567 - can you share your thoughts, or send me a pm?
Thanks, Jason
'79 911SC Targa |
Driver
Good luck getting your parts back. Not saying it won't happen, but if I left stuff sitting around in just my own garage for 4 months, I might not be able to find it. Someone else's garage who's been too busy to even call you back?
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
Titanium User
Locally, there's 2 places I trust. Speedwerk in Nyack, and Gaspare in Mahwah. Which is what I told, Jared. The places rxtrom recommended are great too, just a bit of a hike for me. Wish I was closer, Danny Jacobs is one of the best.
Is Jim Newton still going in....Canton CT? (bit of a hike) Rick DeMan up the Hudson in Blauvelt, NY has a solid reputation ...DemanMotorsports.com. Fairfield County Motorsports in Fairfield CT is right next to the train station so it's easy in/out. About an hour up the rails from Grand Central Fairfieldcountymotorsports.com
Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B] |
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Sometimes, we can't see the Black Forrest for the pine trees.
I do believe the shop's nonresponse rings as the loudest answer to your questions... "I just want to know whether all the parts he needs for the job are in, and whether he has the capacity to do this work." TBD on the parts, but totally clear he does not have the capacity. I'm a patient guy and all. In fact, I often tell my service / repair partners that A) I'm not in a rush, and B) as a result, I value the quality of the work / repair over the turnaround time, but C) I have very high standards so don't accept the job if you can't fulfill my requirements in a reasonable time frame. Regarding completeness of your parts, post the list up here. You'll know within minutes what you may be missing.
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
That's a growing fear. I have a parts list from Pelican and a delivery confirmation, and I doubt he's even opened the boxes. But who knows. I'll head up on Friday to pick it all up. It's a shame. Hoping to line up another shop so that I can just drive the stuff from his shop to the new tech, and I'm not spending days transporting stuff back and forth. I really do not have time for this ****.
If it were spring and not the arctic outside, I'd say swing by on a Saturday with a six pack at my place, I have all of the tools to do the job. Looking forward to hearing the solution. I agree, get your gear and find a reputable shop that wants your business.
