what is correct nylon washer for H4 rim screw
cannot locate a part number for the small nylon/plastic washer for the H4 headlight mounting screw. Can someone provide the part number or a source of what you have used. Thanks
Try these p/n's, first one is the mounting screw that includes a washer, the other is the washer used for the trim ring. Don't see an individual part number for the mounting screw nylon piece.
911 631 033 00 113 951 539
Ralph W Instagram @ ralphwlll 1990 C2 Cab 2006 Nissan Frontier 1986 F250 |
