Tachometer Disassembly Help
Watched some youtube DIYs ang got as far as prying the bezel off, unfastening 4 screws but the face still won't drop from the can/body. I think it's the bronze fastener at the bottom. Wanted to see if anyone has done this before and has some tips before I start monkeying around. Thanks in advance.
http://forums.pelicanparts.com/uploa...1624838123.JPG http://forums.pelicanparts.com/uploa...1624838123.JPG http://forums.pelicanparts.com/uploa...1624838123.JPG |
You need to remove the small black screw at the bottom of the face. Then the whole movement and face will come out.
Sent from my SM-G991U using Tapatalk |
thank you i was thinking the same and started doing so but wanted to be sure...worried about scratching
Thank you for the help. Got it done and retrieved the little bulb rattling around in there.
| All times are GMT -8. The time now is 06:15 PM. |
