69 911t
Aussie Jim new to forum
Rear passenger side lights are out.
Even after changing bulbs. Is there a separate fuse for them.
Also indicators suddenly stopped working
Any ideas. I’m in ct. and just joined the pca.
But have a lot to learn. Would like to talk or text with anyone with an elderly 911.
My number is 8604915349.
thanking you in advance. Jim.
Old 04-19-2022, 02:59 PM
Crusty Conservative
silverc4s's Avatar
1969 911 wiring is unique. First yr of long wheelbase, used different connectors and others. Make sure you use correct wiring diagram to troubleshoot.
Good luck, others will be more helpful, welcome aboard, you have a great car there!
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 04-19-2022, 03:38 PM
Welcome Jim - might want to make sure you are actually getting power there (or aren't) with a multimeter.
The fuses are in the front trunk, driver side.
1967 912 (now w/ 50% fewer random holes in it)
911 w/ 3.2
1974 914 (3.2L swap underway)
1984 928s (S4 engine and suspension), 1987 928S4
Old 04-19-2022, 08:18 PM
More cars than sense
In my experience, everything starts with good grounds. I've learned by experience that step #1 when chasing any electrical issue on an early car is to verify your grounds are good.
JP
________________
Finally! A real online, interactive registry for early 911's! https://early911registry.com
Old 04-21-2022, 05:57 PM
