-   -   tips to loosen tight nuts to remove injectors (http://forums.pelicanparts.com/porsche-911-technical-forum/1096855-tips-loosen-tight-nuts-remove-injectors.html)
ABrit 06-29-2021 11:50 PM
I am attempting to remove fuel injectors for servicing. The nuts on the pipe connectors are really tight and I am having difficulty undoing the back ones both sides. Any tips here would be appreciated. I guess applying heat is out of the question???
Jonny042 06-30-2021 04:44 AM
The manual probably says "remove fuel injectors"
A crow's foot wrench on an extension an a long ratchet handle or breaker bar can be a big help. I have often wished for a swivel-head flare nut wrench when getting at mine.
chrismorse 06-30-2021 05:25 AM
use a 6 point socket and make surei it is fully seated
you really don't want to bugger the bolt head, ( or is t an allen head). I just did this on my wife's benz and they were TIGHT. If you yse an 6 point socket rather than the usual 12 point you stand a better chance of not buggerring the head of the bolt. Make sure it is fully seated and square on the bolt. Or as others have suggested use a crow's foot.
I had to move a bunch of stuff, (dipstick and tube, oil filter, part of the air intake) to get a good shot at the bolt.
use whatever combination of swivel, extension, or wobbly you need to to getback enough to get a good leverage on it.
good luck.
chris
bahman 06-30-2021 06:52 AM
What MY car is this? Can you show a pic of where the line and fitting meet?
john walker's workshop 06-30-2021 08:40 AM
2 wrenches in a V shape and squeeze them together.
bahman 06-30-2021 09:46 AM
Did you mean spreading them out? It's a good technique. I've used on injectors on my '72 MFI system.
ABrit 06-30-2021 01:34 PM
This is a 85 3.2. I have tried the two spanner squeeze but it won’t undo. I realise I need to have a spanner on both sides of the connection but boy how do you apply adequate force. I have a hot air gun to heat one nut but am really worried using it near a fuel line. Lordy Lordy these things are a test.
gtc 06-30-2021 02:58 PM
I just did this last weekend. No special tricks, but having some reasonably long wrenches with narrow flats definitely helped. Maybe soak with penetrating oil for a day if you are having a lot of trouble.
I'm not sure how you could apply much heat back there with the engine still in the car... lots of vacuum lines in the vicinity.
mo-mon 06-30-2021 03:12 PM
Do NOT apply heat. If the injectors are still on & the car runs, go for a spin , warm up the engine to operating temp, & try the john walker technique.
ABrit 06-30-2021 03:14 PM
Thanks I’ll get back and have another go. I’ll not use heat.
mo-mon 06-30-2021 03:49 PM
Oh, if you do get to loosen the nuts, let the engine cool down before loosening all the way.
ganun 06-30-2021 04:06 PM
Remove heater blower, fuel line from filter, 3 connector assembly, to gain access.
Like Walker said, a 15mm and 17mm wrenches in a V and squeeze together.
Gotta have room.http://forums.pelicanparts.com/uploa...1625097613.jpg
ABrit 06-30-2021 09:24 PM
Thanks guys I went back and gave another try after soaking and i got it. On the right side which has good access the nut was done up super tight on the left it was not too bad. I guess whoever did these up over tightened the right side because he could. As you do.
