Sunroof cable bracket - repairable?
I finally got to this item on my to-do list and found the cause for the inoperative sunroof. The passenger-side cable bracket is broken where it pivots and the cable is broken off as well. From what I understand, the originals were plastic and replacements are metal, and since the driver's side is metal I assume a PO did that side previously. Before I lay out $200+ on a replacement I thought I'd ask if this is repairable. It seems a shame to trash the entire assembly because of this broken part. Anyone know if that's possible?
1978 911SC 3.0, 163K+ miles, Copper Brown Metallic |
No fix for the plastic one. Should be plenty of used metal ones around if you post a WTB on the 911 used parts forum.
