-   -   engine experts - question (http://forums.pelicanparts.com/porsche-911-technical-forum/1097195-engine-experts-question.html)
mepstein 07-05-2021 10:42 AM
I have a Euro 3.0 Carrera engine that I'm trying to identify. The engine numbers don't seem to be listed in my book. Can anybody help me figure out the details? Thanks
http://forums.pelicanparts.com/uploa...1625510053.jpg
proporsche 07-05-2021 11:07 AM
it is a puzzle but it also possible the numbers are not original ..seams a little different shape of the zero and 6...
http://forums.pelicanparts.com/uploa...1304183603.jpg
theiceman 07-05-2021 11:25 AM
even the "1" is completely different.
mepstein 07-05-2021 11:25 AM
Here’s the engine. Came out of a euro car set up for the track. Did a quick run before we stripped the car down for acid dip.
http://forums.pelicanparts.com/uploa...1625512982.jpg
proporsche 07-05-2021 11:32 AM
let`s see if David Pateman will pitch in...you do have 1976-77 911 3,0 engine but the side numbers..strange look
Ivan
faapgar 07-05-2021 12:31 PM
3.0 numbers
I just with Mark about this.The # suggests it is a 3.0 built in 1970.Not likely as 74 was the 1st year built for 75 models.The numbers are a bit larger but the font on either side is pretty close.Looks like a blank case that was restamped.Should not matter if you build a hot rod engine.Fred
silverc4s 07-05-2021 03:23 PM
The number seems kind of like Porsche number sarcasm?? Maybe I am overthinking this…
djpateman 07-06-2021 04:22 PM
Well, the 930 type # sure suggests a 1980 engine as opposed to a 1970. I would guess the crankcase casting part #'s are also 930. The 6400001 is a valid serial # but for type 930/07 not 930/02.
The most interesting thing is the serial 6400001 would be the first built. I have a hunch that IF the engine was numbered by the factory, then it was a special. What was the VIN? If it is very low, then we might have something special. What do the engine components fit? That is, what do the parts make it. What are the casting dates?
mepstein 07-06-2021 04:38 PM
Peter Dawe had the same opinion as Faapgar. Unless someone from Porsche tells me different, I'm satisfied with what these two gentlemen tell me.
djpateman 07-06-2021 07:22 PM
6400001 is also a valid 1970 914/6 engine serial #, but not with the engine #'s stamped in those locations, and that sure isn't a 2.0 liter motor either. That leaves 1980 as the correct year IF the factory stamped the numbers.
MAH77 07-09-2021 12:24 PM
What are the casting numbers?
djpateman 07-09-2021 04:25 PM
below the oil return tubes on both sides of the case; L & R are different
http://forums.pelicanparts.com/uploa...1625876673.jpg
