-   -   What happened to the O2 sensor (http://forums.pelicanparts.com/porsche-911-technical-forum/1097499-what-happened-o2-sensor.html)
ABrit 07-10-2021 12:41 AM
My 85 3.2 does not have an O2 sensor. PO must have removed it there is a plug in the exhaust where it would normally go.
Question; what impact does this have on the cars performance and operation.
Question; what the hell would they have done with the wiring connection, I can't find it anywhere. Would they have hidden it behind the engine in the insulation??
I'd welcome some information as to whether I should reinstate an O2 sensor or not.
aus911 07-10-2021 03:08 AM
Hi ABrit,
I think the Euro cars didn't have one. Is your car AUS delivered or Euro?
Cheers
Ray
fanaudical 07-10-2021 11:08 AM
No O2 sensor and I think the ECU just runs the open loop fuel map. The result is probably just reduced fuel mileage.
If you decide to install an O2 sensor, I recommend putting in a wide band O2 gauge with a repeater output and feed that signal to the ECU. That will provide visibility to potential running issues.
brighton911 07-10-2021 05:35 PM
Using a wide band O2 sensor, I have verified the A/F numbers with the sensor in place and without. Without the O2 sensor in place, the A/F is richer by 1 to 1.4 points, so about 13.3 to 13.7 to one at cruise.
ABrit 07-10-2021 08:40 PM
Aha mine is a UK delivered car so maybe no O2. Thanks all for the response if I do go for an O2 sensor I will definitely go wide band with repeater
cmcfaul 07-11-2021 06:57 PM
I recently ran my 89 Carrera with the o2 sensor disconnected. It felt lean. Idled a bit rougher and was a bit faster.
I also have the SW chip. That might have something to do with it.
Lean is fast but can detonate.
Chris
