-   -   78 SC Hazard lights and turn indicator problem (http://forums.pelicanparts.com/porsche-911-technical-forum/1097552-78-sc-hazard-lights-turn-indicator-problem.html)
snbush67 07-25-2021 05:14 PM
Fuse 9 has 2 black/green on top and one black/green on bottom.
Fuse 10 has 2 black/white on top and one black/white on bottom.
http://forums.pelicanparts.com/uploa...1627258225.jpg
Yes, Black/White and Black/Green do go to the center of the signal lamps and the brown goes to ground.
snbush67 07-25-2021 05:40 PM
Problem solved. This is embarrassing.
Wrong bulbs. I had 1156 single filament in the turn signals, it needs 1157 dual filaments.
Thank you Dennis For hanging in there with me.
timmy2 07-25-2021 06:57 PM
Lol, $hit happens.
I figured getting you to poke around enough you’d find something out of order. :)
snbush67 07-25-2021 07:02 PM
Yes, but I’m not sure after the accident if it was working, I only drove it to port at Honolulu then picked it up In Arizona and took it to the shop. I’m not sure if it worked when I picked it up from the shop, only drove it back home and haven’t payed attention until now.
Just glad it’s working and insurance paid for everything.
timmy2 07-25-2021 08:03 PM
It is all good, now you know they work. :)
I even went to my car today to test mine were working in all headlight modes! (They are)
