-   -   3.2 Engine rebuild: Keep 3.2 or covert to 3.4L? (http://forums.pelicanparts.com/porsche-911-technical-forum/1097798-3-2-engine-rebuild-keep-3-2-covert-3-4l.html)
ericwitte 08-26-2021 08:51 PM
Just finishing the build of 3.4: Mahle 98mm, Xtreme CNC’d heads, MK Long tube headers, Sal’s MAF, bored TB, supertec, ARP, 964 cams and Andial extrude honed intake (last 2 were on the original euro 3.2 with an authority MAF and chip and the car was very fast). Car should be finished by October...curious to see what the dyno shows once broken in
auchenberg 03-05-2022 12:47 PM
Update on the project: Ended up being a complete rebuild of the engine
Went with:
- 964 Cams
- 98mm Mahle kit 3.4L conversion
- ARK Hardware
- Single plug
- Motronic with Custom Steve Wong Chip
- 3.2 Enlarged Throttle Body Conversion https://www.911chips.com/engine.htm
- 991 GT3 Muffler
- Custom headers from Rarelyl8. See https://forums.pelicanparts.com/porsche-911-technical-forum/1076156-project-997-991-gt3-exhaust-911-3-2-a.html
- Renovated alternator fan
- New fuel lines
- New oil lines
- New oil pump
- Chain Tensioner Update
- Wevo Semi solid engine mounts
A few photos:
http://forums.pelicanparts.com/uploa...1646512695.jpg
http://forums.pelicanparts.com/uploa...1646512695.JPG
http://forums.pelicanparts.com/uploa...1646512695.png
auchenberg 03-05-2022 12:48 PM
I'm still waiting for the ECU, Throttle bodies, renovated alternator fan to arrive. I'll keep you all posted.
mikedsilva 03-05-2022 02:03 PM
Went with:
- 964 Cams
- ARK Hardware
- Single plug
- 991 GT3 Muffler
- New fuel lines
- New oil lines
- New oil pump
Interesting, I'm doing a similar build but am using a 964 crank.
Did you upgrade your fuel injectors to do the conversion to 3.4? Is it considered necessary?
auchenberg 03-06-2022 08:48 AM
No, keep stock. I should say that I'm doing this renovation together with my mechanic, so I have a helping hand on side here.
Tremelune 03-06-2022 05:27 PM
I hate seeing gorgeous engines because I'm usually happy with my dirty one...
Can you talk about more about the 991 GT3 exhaust decision? How does it compare in terms of noise and weight compared to stock? I have a 3.0 lying around that I'll need a muffler for...I was going to use a stock Bischoff, but the idea of having a switchable quiet/loud muffler instead of a not-too-loud muffler is compelling. I was gonna get SSIs, but it seems your headers are on the custom side...?
mikedsilva 03-07-2022 12:51 AM
Steve told me to keep stock injectors and that 75% of the 3.45litre motors he has tuned, worked fine on them. His website also suggests that the limit of the stock injectors is 250hp. I'm assuming he means wheel horsepower.
Time will tell.
mikedsilva 03-07-2022 12:53 AM
This isn't quite what you are after, but I ran a 997 GT3 muffler on my 3.0 with itbs, big cams and headers. This is only using the quiet ports...
<iframe width="560" height="315" src="https://www.youtube.com/embed/uTsOYe6mhSU" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
jazzyfunkykool 06-10-2024 06:50 PM
Is it possible to get an update on how the car has changed since you've had a the mods a few months ago. Did I read that you daily drive this?
Also, did you convert to MAF or keep the speed density?
fallingat120mph 03-25-2025 09:12 AM
Originally Posted by auchenberg (Post 11391195)
Hi all,
I'm having my engine rebuild on my 1987 911 Targa, as after 106k miles I had excessive oil consumption. It was supposed to be a top-end rebuild, but now that we have dropped the engine, it's evolving into a full rebuild due to leaking main 8# bearing, worn valves, worn cylinder heads, and worn Alusil cylinders + pistons.
I want to keep the car reasonably stock since it's a Targa and a daily driver, but if I anyway will be I'll be in the market for a new cylinder+piston set, I'm currently trying to decide whether I should keep the engine stock 3.2 with a set of Nickies, or I should bite the bullet and go the 3.4L conversion with the Mahle kit?
The car will be fitted with a 997 GT3 muffler + rarelyl8 long tubed heat exchangers, so there should be plenty of air.
My options:
Option 1: Keep motronic + single plug + Steve Wong chip + 964 cams + ARP hardware + AASCO springs + 95mm Nickies with EU/ROW compression
Option 2: Keep motronic + single plug + Steve Wong chip + 964 cams + ARP hardware + AASCO springs + 98mm Mahle kit 3.4L conversion
What would you do and why?
I appreciate your input!
/k
Doing almost the exact same improvements...was there ever an outcome to all of this?
Erik
