Enginerd
TxGerman's Avatar
Rear Center Reflector Installation
I read a bunch of old threads where people had issues with removing and/or installing a Porsche rear center reflector. I knew I was going to be replacing mine when I repainted my SC, so I tried to be as prepared as possible "when the day came".
I decided to repaint my car at the beginning of the year, I ordered all my parts and then thought more about how I was going to mount the new reflector. I could install the new one with the OEM Porsche clips, but I also know that is mostly a one-way trip and will frequently result in damaged plastic bosses or worse yet, a broken reflector. I wanted to come up with an installation solution that could allow easier removal and less likely to break the expensive reflector.
So, I came up with an idea where I would use standoff collars, fender washers and nylock nuts. It worked just as well as I had hoped, figured I'd show and share here to help others that may face this issue and possibly others will chime in with even better solutions.
Original OEM Porsche clip that I didn't want to use.
1"x1/2"x1/2" Aluminum Collar (Amazon), M4 20mm SS Fender Washer, and M4 Nylock Nut
Test Fit
Installed Assembly
1982 Guards Red 911SC, 1994 Riviera Blue RoW 993, 2020 British Racing Green Macan GTS
Gone but not forgotten: 2017 GT Silver Turbo S, 2012 Guards Red 991.1 C2S, 2017 Carrera White Macan GTS
IG: @pcar911fan
Old 03-23-2025, 08:15 PM
Perfect solution , thanks for sharing !!
Old 03-23-2025, 11:50 PM
Nice job. I did something similar when I replaced my reflector after cracking the old one during removal for paint. Those OEM clips are a nightmare!
Old 03-24-2025, 04:38 AM
That's really nice, the clips really are terrible. Good idea and thank you!
1982 911SC
Old 03-24-2025, 07:19 AM
fallingat120mph's Avatar
Test Fit
Installed Assembly
Nicely done! After removing two of these recently I was thinking "there has to be a better way", and seems you found it.
Bookmarking this thread.
Erik
1986 911 Coupe
1986 911 Targa
Old 03-25-2025, 07:14 AM
