Oil pump upgrade kit opinions.
I see our host has a Carrera oil pump upgrade kit for all the air cooled. About $85 bucks.
I have a 67S. Smoke and mirrors or worthwhile. Thanks lyndon |
I won't make more pressure (because of the relief valve). It might maintain operating pressure in a worn motor a bit longer, but if the problem is worn main bearings or such, a bigger pump will only move you a bit farther down the road before the BIG failure.
What exactly does it do ??
Lyndon |
