-   -   3.6 conversion idle when warm question.thoughts (http://forums.pelicanparts.com/porsche-911-technical-forum/1097970-3-6-conversion-idle-when-warm-question-thoughts.html)
Kevin Stewart 07-16-2021 10:05 AM
Hi guys I have a 1982 sc I did a 3.6 conversion about 20 years ago cars been sitting for years I do start it a few times a years. It was a daddy daughter project when my daughter was 13. Anyways gonna get it going to drive as much as we can. it starts and idles but after warming up it dies and have to keep it reved. its almost like a oxygen sensor. I have been reading about the icv idle control valve?. Anyone have this problem on a 3.6 conversion. It might be time to figure out a obd port.Thanks, I really appreciate all of you. Kevin Stewart
Kevin Stewart 07-17-2021 08:19 PM
Anyone?
911obgyn 07-17-2021 08:41 PM
What intake, injection?
walt 07-18-2021 04:19 AM
Have you cycled through some fresh fuel during the 20 years? Cleaning the ISV valve is easy and can't hurt so I would try it. Check for any obvious vacuum leaks. If your fuel is relatively fresh I would then move on to checking fuel pressure.
Another easy thing to try but maybe a long shot is to reset your DME. Disconnect your battery for 10-15 minutes and restart.
Kevin Stewart 07-18-2021 10:18 PM
Stock injection the motor is 92 or a 93
Kevin Stewart 07-18-2021 10:20 PM
Getting ready to drain the tank it’s always had stabil and 50/50 race fuel any threads on cleaning the isv thank you.
walt 07-19-2021 05:06 AM
There is a Pelican technical article on cleaning the ISV:
https://www.pelicanparts.com/techarticles/pcar_com/993_idle_stabilizer_valve_cleanout.htm
This was easier on my car with the plastic intake runners. Maybe a 30 minute job.
Kevin Stewart 08-06-2021 09:41 PM
Part one video sucks but I think this is easy enough for anyone to do. This is a plastic manifold car 3.6 in a 82 sc. you will need one or two preferably Porsche clamps check to see if you have the pinch clamps or one that can be loosened with a screw driver if you have pinch type you have to pry it open or cut it with side cuts be they will need to be good side cuts. Some type of cleaner I used brake cleaner. Video will not load. http://forums.pelicanparts.com/uploa...1628311278.jpghttp://forums.pelicanparts.com/uploa...1628311435.jpg
http://forums.pelicanparts.com/uploa...1628311478.jpg
