-   -   Name that brake failure mode! Pedal goes to the floor w/o warning. Stranded. (http://forums.pelicanparts.com/porsche-911-technical-forum/1097991-name-brake-failure-mode-pedal-goes-floor-w-o-warning-stranded.html)
famoroso 07-16-2021 04:49 PM
Ok, here's the situation.
1989 911 with 135,913 miles. Sitting in a parking lot in Santa Fe Springs for the last 5+ hours, waiting for a third flatbed.
Dropped the car off at Perfect Lines in North Hollywood for a sunroof delete on June 7. Picked it up today, July 16, for the 117 mile drive home to Carlsbad / Encinitas.
http://forums.pelicanparts.com/uploa...1626481477.jpg
47 miles into the drive, while doing 65 mph on I-5 Southbound, I applied the brakes and the pedal went to the floor, without the car slowing at all. I applied the pedal a few more times with the same result. I then pumped the brake pedal, no improvement.
The pedal felt exactly like it would were a brake bleeder screw open... straight to the floor with very little effort and ZERO braking action. The brake system warning light in the dash did not illuminate.
I was able to use the handbrake to slow the car down, move into the right lane and take the next exit. I pulled into a commercial complex parking lot, in Santa Fe Springs, and shut the vehicle off.
I popped the frunk, expecting to see an empty brake fluid reservoir.
http://forums.pelicanparts.com/uploa...1626481348.jpg
It was at it's normal max level. I looked around the master cylinder and the brake calipers for leaks. None found.
I called my Porsche factory trained master mechanic uncle and described the problem to him. He said while he has never been able to figure out this particular failure mode, it did happen to his customers back in the day. They always just replaced the master cylinders.
As I was speaking to my uncle, about five minutes after pulling off the freeway and shutting the car down, I began to remove the driver's side floorboard (to inspect the pedal box) and brushed the brake pedal with my hand. It felt normal. I pushed the pedal with my foot, it felt firm / normal. Started the car and drive it around the parking lot a few times and it feels normal.
Not wanting to risk anything, I called my insurance company's, American Modern, roadside assistance line, only to have them claim the car isn't listed on my policy (even though I have a proof of insurance card showing it).
So, I call AAA at 2:30p to order a flatbed. It was supposed to arrive before 4p. I get a call from Hadley Towing at 5p claiming the truck that was slated to arrive broke down. So, I call AAA back for my third attempt at roadside assistance and here I sit, waiting for a response, posting on Pelican from my handheld.
So, I thought I'd post a "Name that brake failure mode!" thread here and get the collective group's thoughts. Any ideas?
I'm having a hard time reconciling M491 / turbo brakes that were working perfectly fine moments before, untaxed (it isn't like I was on the track), completely failing for at least 2-3 miles and then all pedal feel coming back less than 10 minutes after shutting down? No brake warning light, no easily discernable leaks. Both circuits failing concurrently? And now the pedal feels as firm as ever in less than ten minutes of sitting. I've started the car a few times and driven it around the parking lot and the brakes feel... Normal, which is to say firm / great.
So, whaddaya got? Any ideas, or is this the beginning of me losing my mind?
http://forums.pelicanparts.com/uploa...1626482010.jpg
porsche930dude 07-16-2021 05:09 PM
I think id bleed the brakes at the back where the line gets cooked by the cat. just a guess
famoroso 07-16-2021 05:22 PM
Thank you.
B&B headers FWIW.
manbridge 74 07-16-2021 05:25 PM
Seen it with contaminated brake fluid where the customer adds oil or power steering fluid. Causes seal failure inside M/C. I’d start with the M/C if visible leaks are absent....
famoroso 07-16-2021 05:28 PM
Thank you. Hadn't thought of someone introducing contaminants.
porsche930dude 07-16-2021 05:34 PM
my brother made that mistake at work once. The brake fluid bottle looked exactly the same as the power steering bottle. It happens
famoroso 07-16-2021 06:30 PM
Five hours and fifteen minutes later and I'm finally on the back of a flatbed thanks to Victor at Hadley Towing for accepting a trickier job (low Porsche) that I assume other drivers just passed on the past four hours
Full brake system refurbish / rebuild just jumped to the top of the to do list.
http://forums.pelicanparts.com/uploa...1626488951.jpg
john walker's workshop 07-16-2021 07:43 PM
Caliper(s) drags, fluid boils and becomes vapor, vapor compresses, pedal drops. Fluid cools and brakes are back.
famoroso 07-16-2021 07:46 PM
Thanks! That'll be the first thing I check when she's up on the lift tomorrow. This is a totally plausible explanation!
I'll also check brake fluid moisture content.
Evan Fullerton 07-16-2021 08:34 PM
Not really possible in a brake booster 911 I guess but in my 914 I did have the fuel tank pinch the brake line between the reservoir and the master once the tank settled. Replaced the master twice before figuring out that issue on why the brakes would feel fine during a bleed and then go to nothing after a short drive.
Glad you were able to get to off the freeway without incident.
John W. 07-16-2021 08:42 PM
Scary. Glad you got off the interstate ok. JWs hypothesis makes sense. Let us know what you find.
Ian Comerford 07-16-2021 10:16 PM
Given your explanation of the circumstances I think you will find the master cylinder faulty. There are no visible failure modes but the pedal going to the floor without warning is classic for this
manbridge 74 07-16-2021 10:42 PM
I’d think a rotor would be blued up good if a caliper got hot enough to boil fluid.
mo-mon 07-17-2021 12:19 AM
It happened to me once after 4 intense laps around the track w/ lots of threshold braking. Pedal to the floor but slowly regained the brakes after deciding it was cool-down lap time. Changed brake fluid & all was golden again.
Otter74 07-17-2021 06:39 AM
John Walker’s suggestion is the first thing I’d check for, even with interstate driving. Did you check the temperatures of the wheels when you pulled over? I had a sticking caliper on my car that gave me exactly the same failure mode and subsequent behavior. Rebuilt the offending caliper the next morning.
911pcars 07-17-2021 09:48 AM
MC in trunk should provide easy access. Loosen a brake line fitting on the master cylinder, have a helper apply the brake pedal and see if fluid is forced out. Then repeat on the other brake line. If no fluid pressure, suspect a bad piston seal. Not sure if MC rebuild kits are still available. If not, try a rebuilt unit.
Sherwood
thor66 07-17-2021 12:36 PM
- should be interesting to see the forensic exam on this one...
I forget when the 'safety split' of brake lines happened, but a complete and quick failure on initial application means it has to be in the m/c somewhere.
Boiling fluid should not happen on initial appl. tho you should flush/refill your fluid...
Did that sunroof deleters do any other service on your car?
eastbay 07-17-2021 05:21 PM
++ for JW, You did not say, but have the calipers ever been touched, or are they original?(suspect)
Charles Freeborn 07-17-2021 07:13 PM
Yep. Dragging caliper is my bet too.
I don't mess around with brakes. They gotta work. If they're OEM and untouched they're 32 years old.
If it were my car I'd pull all four send to PMB, then replace all the rubber (braided) lines, probably replace the MC while I was at it, fresh rotors, full flush, thorough inspection of the hard lines. After that you'll be able step on the middle pedal with confidence.
famoroso 07-17-2021 08:49 PM
As per usual, it appears that Herr Walker was correct. Send that man a cigar! (I will be)
Here is a vid of the front wheels, spinning (or at least trying to)...
<iframe width="560" height="315" src="https://www.youtube.com/embed/I4zMvZpjFuQ" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Here are the front rotors spinning with the brake pads removed...
<iframe width="560" height="315" src="https://www.youtube.com/embed/ZSyZ-_hb9K4" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
@Otter74 I did not check wheel temps when I pulled the car over. I will add that yesterday was the highest ambient temps (85+ degrees) that I have driven the vehicle in since I acquired it this past February.
@Thor66 The guys at Perfect Lines only worked on the sunroof delete.
@Eastbay Calipers appear to be original.
@Charles Freeborn A comprehensive brake system overhaul is on the docket. Including, as a result of the above vids, rebuilt calipers at all four corners.
Otter74 07-17-2021 09:28 PM
You would have found that the wheel in question was a lot hotter than it should be.
Rebuilding a caliper isn’t expensive but PMB calipers are quite nice and I hate doing things like rebuilding calipers.
stownsen914 07-18-2021 05:59 AM
If the brakes got hot enough to fail due to a dragging caliper, you would have smelled it. At least once you pulled over, and maybe even from the cockpit while driving. Hard to describe the burning smell, but it's distinctive and very obvious.
Locker537 07-22-2021 08:42 AM
Since they are dragging, have you determined why?
Is the caliper piston(s) sticking?
Brake lines collapsing?
Something else?
911pcars 07-22-2021 09:36 AM
Brake pads will always rub slightly against the rotor without brake system pressure. A secondary function of the piston seals is to slightly retract the pads with zero system pressure.
In that there seems to be excessive rotational friction with the brake pads removed eliminates a stuck caliper piston and/or bloated brake lines. Instead, it indicates the rotational friction might be from another source (e.g. excessive wheel bearing preload, damaged wheel bearing, lack of lube, wheel weights rubbing on hub/caliper, etc.).
MHO,
Sherwood
famoroso 07-28-2021 03:39 PM
After hundreds of track events and race weekends over the past 30 years, I am familiar with the smell of hot brake pads doing their thing (I LOVE the smell of brake pads in the morning!). However, in this instance, I didn't smell anything, even from the cockpit while driving.
Something else?
I have not yet determined why. I had three days to get the car ready for paint, so apart from the two tests above (spinning the wheel with the car in the air and spinning the brake rotor with the pads out), I have yet to find the smoking gun. I trailered the car to the paint shop on 7/20. It'll be there for eight weeks, at which point it'll go to the upholstery shop for 3-4 weeks. After that, I'll trailer it home and work on the brakes. The two videos suggest it is sticking calipers / swelled lines and not "something else." Regardless, at a minimum, all four calipers will be sent to PMB or Tru6 for rebuilding and I'll replace all rubber lines.
MHO,
Sherwood
Except that, per the second video above, there is no rotational friction with the brake pads removed.
Calipers will go to PMB or Tru6 to be rebuilt. Most likely Tru6 as I need to have a number of other items coated / plated.
Locker537 07-29-2021 05:41 AM
Frank, the car is going to be a hoot when done...
Jack Stands 07-29-2021 06:30 AM
New paint and nicely refinished PMB Calipers would be a lovely combination. Brakes and steering are the two most important controls on your car.http://forums.pelicanparts.com/uploa...1627569012.jpg
famoroso 07-29-2021 12:13 PM
Oh yeah!
Steering rack rebuild and Quaife Quick Rack rack & pinion install are on the to do list (along with replacing / refreshing the rest of the running gear) while the paint is curing.
mikesarge 07-29-2021 02:27 PM
I'm going to 2nd this. It's either the master or the booster IMO.
panzerfaust 07-30-2021 10:06 AM
Master seals… my guess. I’m replacing mine on a M491
fbarrett 07-30-2021 11:41 AM
If you don't know how old the flex brake lines are, replace them. Old lines come apart inside, and the crud blocks return flow, so the pads keep rubbing the disk. As the car sat for a short while, fluid seeped back through the blockage, and the brakes felt normal again.
sugarwood 07-30-2021 11:49 AM
Something else?
http://forums.pelicanparts.com/porsche-911-technical-forum/1077935-what-exactly-happens-when-caliper-seized.html
john walker's workshop 07-30-2021 11:52 AM
Heat, heat, baby.
pmax 07-30-2021 12:28 PM
Test the brakes periodically when driving ... any car, not just our 40 year old classics ...
kltarga72 07-30-2021 06:23 PM
Plus 1 with caliper issue.
Had a similar experience, when given time to cool brakes returned to normal. I always carry a laser temperature gun in glove box and was able to diagnose which wheel/caliper was faulty.
Car sat at shop for several weeks so could be either stuck caliper or master cylinder
Shaun @ Tru6 07-31-2021 04:36 AM
Hey Frank, scary stuff, I just rebuilt the right rear caliper on my M491, it had a slight drag. One of the pistons had a wear mark on it. New piston, new seals, it was good to go.
I'd be happy to do your set with the steering rack. Vents is looking great as a slick top!
Pics of a set I did a while ago. We ended up getting all new pistons as most were bad
http://forums.pelicanparts.com/uploa...1562807839.jpg
http://forums.pelicanparts.com/uploa...1627734336.jpg
http://forums.pelicanparts.com/uploa...1562808037.jpg
famoroso 07-31-2021 06:22 AM
W00T!
Looks amazing!
I need to put a list together (calipers, steering rack, front control arms, etc.) for you so we can coordinate / define project scope.
famoroso 08-01-2021 05:08 AM
I know how old they are... 33 years old. They're slated for replacement once the vehicle returns from paint and upholstery.
Great thread, thanks for sharing.
Amen to that brother pmax!
Thanks for the tip. I'll add a mini IR temp gun to my toolbag.
Thanks for all the responses and input here. It takes a village. I'm probably going to go through and refresh the brake system on my 1987 too.
