CO adjustment on 3.2 Carrera.
I do not have a CO tester but I wanted to put the adjustment at a base adjustment until I can get to a shop. I turned the bottom mixture screw clockwise hoping it would come to a stop but I can’t seem to get there. If I do get to the stop I was told about 3 1/2 turns counter clockwise should get me to a base setting. Does that sound about right? Thank you. Nick
Old 05-22-2023, 05:15 PM
Make sure your turning it clockwise as if you were looking from the bottom. The screw should stop, if not there is an issue. I would pull the AFM then and see what is going on. Also for me I decided to get an unmolested AFM from a 996 as I knew mine was cracked open and the spring adjusted for some reason. After putting in new fuel lines, injectors, gaskets, fixing vacuum leaks, I wanted a baseline AFM.
Old 05-22-2023, 05:38 PM
917_Langheck's Avatar
There is a procedure written up somewhere here that discusses how to set up a base setting without the use of an O2 analyzer. Unable to find it via my phone, unfortunately.
Old 05-22-2023, 09:00 PM
You can use the voltage off the O2 sensor as a rough estimate.
I believe its about .9 volts but would have to check that.
Old 05-23-2023, 05:21 AM
