-   -   Whats this sensor (http://forums.pelicanparts.com/porsche-911-technical-forum/1098206-whats-sensor.html)
cmcfaul 07-20-2021 07:16 AM
Whats this sensor
I cant seem to find this sensor as mine is broken. What is it?
Thanks,
Chris
89 Carrera
http://forums.pelicanparts.com/uploa...1626790508.jpg
jbell959 07-20-2021 07:24 AM
I believe that is the temp switch for the fender oil cooler fan
cmcfaul 07-20-2021 07:28 AM
That was my first thought. Would explain why the fan never comes on (though my car runs cool without it).
Any downside to making it a manual switch?
Chris
89 Carrera
JRSIII 07-20-2021 07:29 AM
Unless it changed from 88 to 89, the temp switch for the front fender oil cooler fan is located on the top of the oil cooler itself....
cmcfaul 07-20-2021 07:37 AM
The replacement part on Pelican does not look anything like what I have (pictured above)
Chris
89 Carrera
JRSIII 07-20-2021 07:57 AM
Looking at the PET, that appears to be a temperature switch, but it's not the one that activates the front fan. Check out part 93060611800.
HaroldMHedge 07-20-2021 10:48 AM
This sensor controls the engine compartment electric heater fan. It pushes additional air through the heat exchangers which is dumped under the car. The sensor is the same one that is mounted on top of the front oil cooler with a fan, 87-89..
86 911 Targa 07-20-2021 10:55 AM
Sensor
Confirmed by my factory service manual.
Gerry
