Replacement Fuel Line Fitting? Tunnel Return Line Engine Side
Hi there, curious about where to find a replacement fitting for the poly return line I battled today. The poly side fitting ended up rounding off on me, so I cut it out of the line :mad: The pic below shows after I had cut the metal return line, cut the poly side out of the hose and used my big impact gun and a vice to separate the two.
I've looked all through belmetric and can't seem to find it. Having a little trouble with keywords to find this thing: 6mm barbed hose adapter with 14mm x 1.0? threaded external cone end :eek: https://i.imgur.com/wjFOB4I.jpg?1 PS: Is Len still around? He hasn't replied to my emails over the last few months. |
His profile shows he posted a couple days ago.
| All times are GMT -8. The time now is 11:23 AM. |
