Any unique ideas for interior headliner?
Does anyone have any interesting ideas or pictures, yes, pictures are needed...of cool / unique /weird / wonderful / interestingly executed Headliners?
Not sure anyone does much beyond install a new one? Any other ideas?
I think this applies to non-sunroof, but open to seeing Sunroof cars as well.
LittleOldMan Incorporated
Franchising Opportunities Available
Old 01-19-2023, 06:47 PM
lateapex911's Avatar
The qualities the stock headlineer brings are: acoustic, cleanability, and thin, so that it can be glues around the windshield and window flanges.
The holes help the interior vent thru the rear roof vent, but an open weave fabric could do that without punched holes.
So any fabric that's not prone to mold and is good in humid conditions and is thin, would work using the stock hoops. That opens a LOT of possibilities.
I'm not sure where the line on thickness gets drawn as too thick for wrapping around the flanges.
Now, if you change the mounting method and do away with the steel rood/hoop things, you could shape foam and glue in a wide array of things, such as alcantera.
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 01-19-2023, 09:08 PM
Interesting ideas:
A ‘starlight’ headliner (a la some current Rolls Royce cars) with fiber optic (or whatever lighting) in some of the ventilation pinholes
Paisley, a la Chrysler Mod Tops.
Tartan on the seats only isn’t enough!
See the interior of the Pierre Cardin Javelin
You asked!
'80 SC Targa
Avondale, Chicago, IL
Old 01-20-2023, 06:00 AM
[QUOTE=Otter74;11901546]Interesting ideas:
^This
Old 01-20-2023, 06:03 AM
Ok. Maybe Pasha headliner?
Anyone do away with headliner all together? Any ideas there?
Old 01-21-2023, 07:33 AM
How about purple fur, like that awesome Gremlin that was on BaT recently?
'80 SC Targa
Old 01-21-2023, 10:01 AM
Eng-o-neer
Tremelune's Avatar
This thread is worthless without pics.
Old 01-21-2023, 12:22 PM
Carmagic.us
rothaus's Avatar
Check this one out.
R / Outlaw project...
Cheers
Engelbert
For BA7s Dash LED, and External Marker LED go to carmagic.us - Now Luftgekühlt Emblems
Old 01-21-2023, 12:43 PM
I installed a simple red felt in my outlaw, just to help with the drumming, like the 911R’s did.
Old 01-21-2023, 01:32 PM
That’s a great idea. I like it.
Can you share more. What kind of felt? Did you simply cut and glue to the roof metal?
And does it control road noise?
I was thinking a think batting/foam cut and glued to roof. Then an alcantara or other glued to that for a slight squishy feel (if one touches the roof).
Old 01-22-2023, 12:12 PM
I glued it right to the roof, no padding. The car is a former race car and it’s pretty loud, it helps enough. The 911R’s used this red felt, and when we did restorations on them, we sourced it from TRE in Van Nuys I believe.
Old 01-22-2023, 01:34 PM
