-   -   I wanted to say something nice about URO Parts but.... (http://forums.pelicanparts.com/porsche-911-technical-forum/1098424-i-wanted-say-something-nice-about-uro-parts-but.html)
Hi_Fi_Guy 07-23-2021 09:52 AM
I have been critical of URO Parts in the past for poor quality and appearance. I thought their aluminum visor clip might change my mind.
First the good:
The visor clip is made of metal instead of plastic. This was a major draw as the plastic clips seem to "round out" on the inside allowing the visors to flop down and not stay up.
I also noticed the clip features a set screw inside to further reduce the likelihood of failure.
Overall looks like a well thought out replacement part.
http://forums.pelicanparts.com/uploa...1627061929.jpg
Now for the bad:
The price is quite high at $24 per clip (you need 4) plus any tax & shipping.
The metal shaft which needs to be inserted into the visor is too long. The visor has some sort of framework or something inside that does not allow the longer shaft to be inserted fully. I tested and these longer shafts on an original Porsche visor and an aftermarket reproduction. Neither would accommodate the longer shaft.
Pelican website says these are the correct pieces for my 1971 911 Targa. However the shafts are too long and do not fit the visors. I guess I am stuck returning them or cutting them to fit... which should not be the case at this price point.
john walker's workshop 07-23-2021 09:56 AM
So cut them. Easy.
Hi_Fi_Guy 07-23-2021 10:00 AM
Originally Posted by john walker's workshop (Post 11401160)
So cut them. Easy.
That may be the easiest solution John. I posted this info mostly as an FYI for others who may be looking at these parts.
gwmac 07-23-2021 10:27 AM
I too have trouble finding nice things to say
john walker's workshop 07-23-2021 11:15 AM
Tell it to URO, they are pretty responsive.
proporsche 07-23-2021 11:22 AM
As John ,said modify it..i have a Q..did you get the bracket for Targa or for Coupe?Targa take the longer pin .coupe takes shorter....are your sunvisors original to your 911 targa??
Ivan
Hi_Fi_Guy 07-23-2021 11:44 AM
Ivan
Pelican says the URO parts I ordered are correct for my Targa.
Original Porsche visors as well as replacement visors ordered specifically for Targa match each other but not URO part.
Otter74 07-23-2021 12:39 PM
When my visors wouldn't stay up, I got an X-acto knife and cut a shim from a Coke can to put in each visor bracket. It's held up for five or six years, and when it starts falling down again I'll just do it again.
proporsche 07-23-2021 12:45 PM
if your wiser does not stay up isn`t that the screw there for it to adjust the tension?
Ivan
Hi_Fi_Guy 07-23-2021 03:55 PM
Ivan
The failure is not on the visor tension side. These fail at the plastic mounting clip. The plastic cracks or rounds out inside allowing the the visor pin to spin freely instead of staying in place. The set screw and metal construction of the URO pieces are supposed to solve that common failure point.
gwmac 07-23-2021 04:44 PM
Bingo,
tried to use their plsatic dash clips.
garbage
rep was nice, wanted to know lot etc.
last I heard.
very similar to reps in my industry.
very interested at first then they realize they are selling junk and no more communication.
5495bb 07-23-2021 05:47 PM
Oh come on, it's European car from 1971. Did you really expect the Visors or the AC or the Power Windows to work for more than 5 weeks. OK maybe 8 weeks because it's a German car. I think that URO is making the correct parts for the correct amount of period correct frustration
pmax 07-23-2021 06:08 PM
So cut them. Easy.
At this juncture of life, I would say there are two choices for our OP, either shorten the pole or deepen the hole !
Hi_Fi_Guy 07-23-2021 09:01 PM
Ha, ha, ha. Great response.
UROParts 07-27-2021 10:50 AM
The Porsche part numbers for these pivots have a lot of supersessions and the fitments are a bit murky, but in general our long-pin "late-style" pivots 964 731 320 40-PRM and 964 731 319 40-PRM should fit 1975-1989 Targa and 1978-1989 convertible. They may also fit 1970 to 1974 Targa depending on depth of hole in visor.
For 914, our fitment data includes the note: "May require reuse of the original pivot pin", perhaps all 914's require short "early-style" pivot pins. It's likely one (or more) of the superseded numbers (911 731 016 40, 911 731 324 40, etc) are short-pin pivots.
Sorry we don't have concrete data, does anyone have a solid handle on the history of these applications?
UROParts 07-27-2021 11:06 AM
Originally Posted by gwmac (Post 11401559)
tried to use their plsatic dash clips. rep was nice, wanted to know lot etc.
Hi Gary, we submitted a complaint to our Engineering department on 4/30/2020, checking with them to see what they found out. It's odd, we sell about 3,000 of Dash Clip 999 591 310 40 annually with zero returns or complaints. They are an inexpensive item though, and often low cost items don't get returned.
Will let you know what they say.
Hi_Fi_Guy 07-27-2021 09:35 PM
I appreciate the response. I have 2 sets of 1971 Targa visors. Both with the short style pins. Both visors feature internal structures which do not allow use of the longer pins.
I was able to cut down the longer pins on the URO units and grind a smooth bullet shaped tip on them and use them. That said the part is not inexpensive at about $100 for all 4 so it would probably be better for URO to offer a shorter version for early cars.
At the very least communicate with Pelican so they don’t display the message, “this part fits your 1971 911 Targa”.
I will also admit Pelican was surprisingly unhelpful when I contacted them about this part not fitting.
All that said the aluminum clip with set screw is a nicely thought out design and I am hoping for many years of trouble free service from these parts.
UROParts 08-04-2021 08:21 AM
tried to use their plastic dash clips.
Hi Gwmac, sorry we dropped the ball and didn't report back to you last year on this.
Our engineers checked out our inventory and found that our clips are slightly more flexible than OE, and take the same amount of force to push in and remove as OE. They popped several clips in and out of the hole several times, and had no breakage. We sell about 3,000 of these clips annually, and have had zero returns or complaints. It's a mystery.
Thanks for the heads up though, we've instructed our QC department to closely inspect all future production runs, just to be safe.
theiceman 08-04-2021 08:45 AM
certainly looks like they gave you the shaft on this one..
theiceman 08-04-2021 12:34 PM
Originally Posted by Joe Bob (Post 11412961)
Your company still sucks donkey balls. It took me year to get a refund on vintage fog lights that you GUARANTEED to have 12 volt bulbs....I only found them in Australia for 32USD a bulb.
I will ask my progeny to haunt your slimy ass.....
ok i'll admit it , i had to google progeny....
