pertronix and timing
i posted a week or so ago about putting in a pertronix and setting up the timing on 1975 2.7 s motor. the vacuum pump is no on the car. i set the timing at 5 atdc at 950 rpm. this is what is shown on the sticker inside the car. is this correct? or should i set it for the 35 btdc at 6000 rpm instead? which is best?
it seems to run hotter than it did before i changed the to pertronix and moved the distributor. but it runs really nice with great torque and zips to redline without any hesitation or pinging. gary |
do the max at 33 and see how it feels.. I try to be a little conservative for the summer because of summer heat and lousy gas. your mix should be checked after retiming, I like it on the high side........Ron
| All times are GMT -8. The time now is 07:31 AM. |
