1988 Carrera
Just a heads up
Back in Jan. 2016 I changed my alt. I purchased a Bosch unit from our host. I did this in my garage so all tools were on hand. The old alt. had a 24mm nut and the new on had a 22mm nut. Not thinking a thing about it at the time. All goes well, no problems. I just bought the black plastic nut cover and it did not fit the 22mm nut. I replaced the 22mm nut for the 24mm nut.
All this time I was driving around the country not knowing that there was no way I could replace the fan belt as the tool kit does not have the needed 22mm wrench So the moral of this story is check your alt. nut if you have changed it out.
88' Carrera 79' SC gone (lost to Katrina) 75' Targa gone 72'914 gone 72' 914 gone too |
