Clutch pedal engagement ?
Well today was a great day, she moved and more importantly stopped today. I did a master cylinder and pedal assembly last year and just got to finishing the brake bleed and test today!
I am sure she needs some dialing in, but I am wondering where your clutch pedal engagement should be? Mine is very very high, as it was before the new bits, but I want to adjust it. The clutch is brand new fyi. Thanks, |
I always go by - Starts to engage at 1/3 pedal travel and fully engaged by 2/3 pedal. Did you use the recommended procedure with feeler gauge at the transmission.
Walt 82SC 3.0 81SC 3.6 |
Vintage Owner
What year is your car? The adjustment procedure changed several times depending on your clutch setup?
84 Targa (sold) 70 914-6 (sold) 73 914-6 2.7 conversion (sold) 75 GMC Motorhome (sold) 2016 Cayenne |
ger. loosen your clutch cable 15mm open wrench ......it is too tight
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
It's an 82SC.
I figured i'd go back through the adjustment steps... just to be sure, it just grabs a lot higher than my other cars. 4 cars 4 different clutch and trans feels... lol |
New clutch should engage low. Mine is near the bottom, but 1/3 up seems common.
'80 SC Targa Avondale, Chicago, IL |
Ivan
Sure, but if you have a new clutch that engages all the way at the top, as it wears (granted, this will be a while) then you run out of room for complete engagement.
Ivan
