bivenator's Avatar
AC condenser high pressure/suction manifolds
I am installing an AC and am in need of the high pressure and suction fittings for the condenser. A very difficult time finding these items. Couple of questions
1. I have hit dcAutomotive, LAdismantlers, atlantaperimeter. Am I missing somebody?
2. I did find a new high pressure side (180$) but no suction can be found. Suggestions for new part location
3. Are there any options that are not Porsche?
4. Any in your garage?
Thanks,
Scott
the unexamined life is not worth living, unless you are reading posts by goofballs-Socrates
88 coupe
Old 07-28-2021, 01:45 PM
Hi Scott,
I am assuming that you are looking for manifolds for the AC compressor on your 88 coupe.. yes they can be tricky to find..
If your 88 coupe has stock AC, here are some part numbers off the PET:
Compressor - 930 126 021 01 - Denso 10P15C
Pressure Valve - 930 126 925 00
Suction Valve - 930 126 923 00
Did a search on Ebay, and both are available:
https://www.ebay.com/itm/255056392218?epid=1891419868&hash=item3b628bb01a:g:Z5wAAOSwXPxg8f5x
https://www.ebay.com/itm/255056394808?hash=item3b628bba38:g:fQkAAOSwC8Ng8f9 v
It is also sometimes possible to find used compressors which also have the manifolds attached, for example:
AC compressor 911 Porsche Denso
For options not Porsche, there is a reference to a non-porsche part in this thread:
Where to get Nippondenso A/C compressor manifold.
There is a possibility that it may not fit right though, so you have to check carefully...
Good luck with your search.
cheers,
Jeff
Old 07-28-2021, 07:14 PM
bivenator's Avatar
Thanks so much 2aircooled. Thats fantastic and truly appreciate the help.
Scott
88 coupe
Old 07-29-2021, 08:27 AM
