83 SC window issue
I have replaced switches in the past....but the driver door is being a PITA. The dial doesn't want to pop up the plunger, now I can't push it down manually. The door locks and unlocks with the key.
Simple lube down the hole? OR...Any suspected culprits or do I need to pull the door card and explore? |
| All times are GMT -8. The time now is 07:50 PM. |
