-   -   Yellow wire from Starter Motor run directly to the ignition switch? (http://forums.pelicanparts.com/porsche-911-technical-forum/1099082-yellow-wire-starter-motor-run-directly-ignition-switch.html)
geoff_k 08-01-2021 07:48 PM
I am lazy.
Can anyone tell me whether the cable is suppose to run directly from starter motor to the ignition switch? The car had an aftermarket car alarm fitted and I can see the yellow wire from the ignition switch has been cut and a black wire used.
I pretty sure it does but I seeing a mass of cables and what looks like yards of electrical tape I need to unravel.
Asking for the advice before I start it on Saturday..or maybe Sunday..am feeling lazy at present
cmcfaul 08-03-2021 07:04 AM
I did that On my 73 E. harness connector was not connecting properly so bypassed in a couple places (Starter and oil pressure).
boyt911sc 08-03-2021 07:16 AM
Yellow wire to starter.........
Originally Posted by geoff_k (Post 11410041)
I am lazy.
Geof,
The yellow wire from the starter is connected to the ignition switch @ START (terminal #50).
Tony
T77911S 08-03-2021 07:32 AM
i suggest getting the bare metal crimps, crimp the wires then solder the wires in the crimp then put heat shrink over it. (put the heat shrink on first).
you can also just solder it together then use heat shrink.
timmy2 08-03-2021 07:46 AM
Yellow solenoid wire runs from starter to the 14 pin connector at the rear fuse panel, then through the body harness to a connector in the trunk on the back of the 6 pin ignition connector that goes through the dash sheet metal. The ignition switch has a small harness that plugs into that connector under the dash.
tschall 08-03-2021 10:03 AM
Hey guy, maybe I missed it, but what year/model P car? Check out all the info here: http://forums.pelicanparts.com/porsche-911-technical-forum/1097304-ignition-switch-electrical-dummies.html
and follow on to the Secret Sauce Link there for more info...
This forum is ama
zing in the depth of knowledge from hands on guys and gals...
JSV798 08-03-2021 01:41 PM
If it's like my car the yellow wire is cut so that two alarm wires can be spliced in. The two ends of the cut yellow wire should still be visible. The idea is that the yellow wire is rerouted through the alarm and when the alarm is ON the connection to the starter motor is disconnected. If the alarm doesn't work properly then this could prevent the starter motor from operating. I'm sure a knowledgeable thief could easily by-pass this disabling by putting a jumper lead on the two yellow wires.
al lkosmal 08-04-2021 08:35 AM
wiring diagram
Difficult to debug without using a wiring diagram for your 911....here are excerpts from a 78 911....should be similar to yours....
D is the ignition switch
B is the starter
http://forums.pelicanparts.com/uploa...1628094749.JPG
http://forums.pelicanparts.com/uploa...1628094780.JPG
regards,
al
geoff_k 08-04-2021 06:41 PM
thankyou..
I will follow the "Yellow brick" hang on yellow wire.
