Dept store Quartermaster
lendaddy's Avatar
T/O bearing actuation fork and shaft. ???
Now that the horseshoe spring is preloaded the the fork actuation shaft is rather stiff. I would like to know if this is normal or if I have a problem. If I try to turn the splined shaft by hand it isn't easy. But if I attach the lever it moves much better (obviously). I am sure there is plenty of spring force between the spring center and horseshoe spring to overcome this tension, I just wonder if it should be much more free moving. Could this cause undue stress on my TO bearing. Thanks
Cornpoppin' Pony Soldier
Old 05-08-2003, 10:42 AM
lendaddy's Avatar
bumpitty bump bump
Old 05-08-2003, 12:28 PM
