-   -   Refinished fuchs--WAY more work then I planned (http://forums.pelicanparts.com/porsche-911-technical-forum/1099418-refinished-fuchs-way-more-work-then-i-planned.html)
JonT 08-06-2021 01:37 PM
Refinished fuchs--WAY more work than I had planned w/pics
It seems the guys that bead blasted my wheels used too aggressive of media which made it very difficult to get the mirror polished finish I wanted. This is just the first wheel I'm hoping the next 3 don't take nearly as long. I do like how it turned out it was just a very tedious learning process. http://forums.pelicanparts.com/uploa...1628282126.jpg
http://forums.pelicanparts.com/uploa...1628282166.jpg
Gianni at Pelican Parts 08-06-2021 01:42 PM
Nice color choice. Polishing by hand or using some rotary machine?
JonT 08-06-2021 02:03 PM
I did the bulk of the sanding with a dewalt 5" polisher with sanding pads down to 80 grit. I found that I couldnt avoid hand sanding as much as I wanted to. I took the dewalt pads up to a 1500 grit then went back and hand sanded from 320 on up to 1500 again. The circular motion of the pads was leaving marks that had to be hand sanded out. It's definitely not as easy as I was expecting to get a mirror finish.
proporsche 08-06-2021 02:26 PM
looks very nice;-)
Ivan
proporsche 08-06-2021 02:28 PM
JonT 10-16-2021 10:30 AM
Finally on the car now with some Yokohama A052's. Nice sticky tire with a very stiff sidewall so it tightened up the steering response. Very happy with the new look.
http://forums.pelicanparts.com/uploa...1634405249.jpg
http://forums.pelicanparts.com/uploa...1634405294.jpg
http://forums.pelicanparts.com/uploa...1634405431.jpg
bahman 10-16-2021 12:09 PM
Another technique to speed up the polishing process and reduce manual sanding labor is to make the rear of the car act as a lathe:
1. Raise and stabilize the rear of car (jack stands on both sides and floor jack under engine.)
2. Start the car and run it in 4th or 5th gear to rotate the wheels.
3. Wrap proper-grit sandpaper around a flex-pad sanding pad and hold it against the surface to be sanded. Keep a trickling supply of water on the sanding pad.
4. Run it until desire surface finish is achieved.
5. Use metal polish (I use Turtle Wax Professional Metal Polish) and a micro fiber rag to achieve the desired high luster.
6. Apply ceramic coating to prevent tarnishing.
Needless to say, extreme caution must be exercised while the engine is running and wheels rotating. I would not recommend going beyond Step 2 if the car begins to vibrate; may consider lowering the rotation speed.
proporsche 10-16-2021 12:16 PM
looks nice and original ,i like that ..i`d just make the targa bar sign in blue as well so it is balanced
Ivan
Tea Tray 10-16-2021 12:31 PM
What is barbell in German?
When I saw just the wheels I was… like….well…
Then when I saw the stripes, wheels and car I am WOW!
Looks like a barbell, planted, strong, a very powerful statement.
Well done!
911pcars 10-21-2021 10:46 AM
That would be a "car wax" polish containing "ceramic elements", in popular use today as opposed to a high temp ceramic coating (e.g. Cerakote). BTW, Cerakote offers a chrome-like ceramic coating. However, have yet to see it applied to a Fuchs wheel.
As long as you're able to maintain that polished, but unprotected surface (e.g. anodizing), should be fine.
Sherwood
TeeJayHoward 10-21-2021 11:47 AM
*sees first photo* Well, to each their own.
*sees final product* Damn, I was wrong.
Looks great, man!
canamfan 10-21-2021 12:45 PM
They look the part of being well worth the effort, great job on tying in the colour with graphic, very sweet over all
88911coupe 10-21-2021 01:44 PM
These wheels are stunning. Can I ask what type of paint you used? I used some wheel paint many years ago on my wheels and it's held up pretty well but thinking of doing it again.
Reiver 10-21-2021 05:04 PM
Nice work...your garage is the heat btw....sweet
cabmandone 10-21-2021 05:06 PM
A LOAD of work... but soooooooooo worth it when done. Great job!
Frog76S 10-22-2021 10:42 AM
We’ll Done! Great blue color choice and you tied it together nicely with the Carrera stripe without over doing it. One of if not the best none Fuchs original wheel colors I’ve seen executed.
Nice garage space too!
JonT 10-22-2021 01:46 PM
I bought the stripes from a Pelicanite and took them to a local paint shop to match. As it turned out the color was Mexico Blue which worked out perfectly. I used 2 coats of primer, two coats of paint and two coats of clear with sanding in between on the primer coats and paint coats as necessary using a 1200 grit paper. I've never really gotten the perfect results using a rattle can before but the key was the sanding in between coats and patience carefully wiping everything clean with lint free towels after sanding. The finish turned out really nice. There definitely is an art to laying down the right 'heavyness' of coat to get a good finish.
Thanks for the kudos I love how it turned out--looks much better in person I will say.
88911coupe 10-22-2021 03:11 PM
Mexico Blue, and some other blue (Albert) are some of my favorite Porsche colors...as well as some oranges like Signal. Both my 911 have been Guards red...not very adventurous.
BK911 10-22-2021 05:57 PM
Looks great, man!
Yup.
Maybe a polished center cap???
BK911 10-22-2021 06:10 PM
Great looking car!
Love the polished targa bar.
Thinking about polished window trim????
Next level! :D
And a 3.6?
I think "it" moved!!
everforward 10-24-2021 05:20 PM
Looking good JonT. Would you mind sharing the specs on wheel and tire sizes? I have been considering your tires (A052’s), but don’t know if I want to run 50 series sidewalls from my current 60 series. 205/60/R15 (F) & 215/60/R15. If I went with the A052’s the only matching pair would be 205/50/R15 (F) & 225/50/R15 and might require some suspension adjustments. Matching tire sets for 15’s with my current specs are hard to come by these days. I’d like avoid a new set of rims and tires and suspension adjustments. Thanks in advance and I hope my question doesn’t distract from your wheel porn.��
JonT 10-25-2021 06:56 PM
sizes are 205/50/16 on 7" front and 245/45/16 on 9" rear
TxGerman 01-11-2022 04:48 PM
Sherwood
Can anyone provide their experience maintaining polished but uncoated aluminum Fuchs (or even non-Fuchs for that matter)? I have been wondering if it is a PITA or a non-issue.
TIA
everforward 01-11-2022 06:11 PM
Thank you for providing the specs JonT
