-   -   Alignment kit that isn’t overpriced (http://forums.pelicanparts.com/porsche-911-technical-forum/1099483-alignment-kit-isn-t-overpriced.html)
jjeffries 08-11-2021 03:06 PM
Chris, I’ve been following your thread on the 924/44/68 page. Remember, “it’s not a 924, it’s a 924S!” (Point of fun I have with my friends. “It’s the next 73 RS” is another, but that hasn’t gained much traction yet.)
I used gallon-size Ziploc baggies in place of turn-plates. I don’t even spray WD40 or olive oil in them. Work great.
Instead of the boxes (which are heavy because I built them like brick $hithouses), 4 x Harbor Freight motocross stands could work with some tweaking. Keep an eye on Craigslist for a set of real Hunter “tables”. I missed a couple of sets. They are the mac daddy. As are the hub stands sold by 928 International.
Best, John
Knockdown 08-11-2021 04:57 PM
Hub stands aren’t low cost but they sure take the PIA out of DIY alignment. These from CSM Performance back when the offered a lower cost setup.
http://forums.pelicanparts.com/uploa...1628725530.jpg
chrismorse 08-11-2021 05:22 PM
V blocks
Originally Posted by 47silver (Post 11421326)
caster can be read by using a digital level or a camber gage on the wheels.
I hope to try it this weekend and will post what I find.
some also suggested placing the level on the strut above the ball joint and below the strut shroud.
problem with that is being exactly perpendicular to the strut forward to back.
Hi Silver,
How about using V blocks to mount the bubble/digital level for a caster read???
I am about to dive into my second corner balance and just bought a set of "caliper" string blocks - thisis going to be fun :-)
jjeffries 08-11-2021 05:48 PM
That’s a beautiful set-up and you’ll never lose because you’ll always be able to sell the stands if you do desire. It’s tempting for me to try make some …
John
DG624 08-09-2022 12:54 PM
With alignments now $250 I would like to use my alignment tools but I have trouble getting the car off the ground. The hub stands look good but expensive. I also have trouble finding a level area to do the work.
I spent all day waiting for an alignment (86 911) and it was still not done.
I have Elephant camber plates and rear camber max plates. They still had trouble.
Most alignment shops refuse to do early 911s because the rear is so hard to get right.
I can keep dropping $250 at alignment shops or start doing it myself. Is there a DIY repair/alignment story on Pelican?
smadsen 08-09-2022 09:47 PM
1 ball of nylon fishing line
20 or so linoleum squares
3 or 4 60# bags of redi-crete (or a patient girlfriend of equal weight)
4 jackstands which you should already own
2 yo-yos in 1/32nds or 2 wood yardsticks (free @ Ace) in 1/4" increments if you're aligning a NASCAR
1 carpenter's level and the ability to do some 7th grade geometry
This is not rocket surgery.
