Name that leak!
I'm getting a few annoying oil drops. Looks like its under thr 2 senders? Circled in red is the oil.
Old 08-10-2021, 08:48 AM
theiceman's Avatar
warning.. if you try to replace that oil pressure sender remove the block from the case FIRST. Then remove the sender from the block. A few stories of guys breaking their case trying to twist sender off.
rule of thumb with leaks, start with the highest point and move down so sender, cam oil line, temp sender and oil pressure sender are all good places to start
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 08-10-2021, 08:56 AM
New-ish 911SC Targa Owner
pampadori's Avatar
That one leak dripping from the carrier bracket looks like maybe seal behind the pulley. The cam boxes dry where they bolt to case?
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp
Old 08-10-2021, 09:57 AM
proporsche's Avatar
on the engine case is most likely the alu. seal behind the oil pressure sending unit--remove the cam.oil line and the bolt for the O.P.U. replace the alu seal .The one on front very possibly the inter.shaft gasket.Do you have any marking on the bottom of the rear decklid if yes it the the front pulley seal if not it is the gasket.But if you go there do them both.
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 08-10-2021, 01:14 PM
Decklid and cam covers look clean, I wonder why there's oil under pulley cover there. I don't want to change pulley seal just yet, the sender one is first.
Old 08-10-2021, 01:17 PM
Good points all! I am going to drive for a little bit as well. I suspect it was overfilled.
Old 08-10-2021, 01:19 PM
Off topic - think your sump plate should be rotated, such that the drain plug is at 9 o’clock when looking up at it from the rear.
Jason
'79 911SC Targa
Old 08-10-2021, 03:07 PM
T77911S's Avatar
make sure the cam line is not leaking.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 08-11-2021, 04:47 AM
Good call Jason, didn't even notice! Next oil change.
I will clean and wrap areas with tissue paper and see where leak is.
Old 08-11-2021, 07:07 AM
So here is leak and proof. Is this the oil sender? Which gauge does it report to? My 'Oel' gauge doesn't work, just realized right now.
Old 08-11-2021, 11:11 AM
proporsche's Avatar
temp sensor just make it tight or if you have the alu seal replace it easy job;-)
ivan
Old 08-11-2021, 12:29 PM
Nope! Its the oil pressure ofc. So easy to change
Old 08-12-2021, 11:38 AM
proporsche's Avatar
ok as i said i post # 5..correct?
Ivan
Old 08-12-2021, 12:11 PM
Ivan
Yes, exactly! I was hoping it would be the easier one to swap.
Old 08-12-2021, 01:17 PM
proporsche's Avatar
good to clarify for future peeps;-)
Ivan
Old 08-12-2021, 01:23 PM
