bcgreen's Avatar
Has anyone taken the needle off of the 911 speedometer?
I am curious as to what you used and how you did it. I am thinking of doing it on my '76 Carrera. Need to replace the gears and this is the only way of knowing of how many teeth there are. I know most everyone was sweating bullets at least those that posted here, I don't know anyone who did it without any stress.
66 Shelby Hertz Renta-Racer
68 Shelby 500KR
78 Ferrrari 308
16 Macan S
11 Speedster
Old 06-09-2018, 05:09 PM
I tried to take the needle off of the tach so I could re solder a connection on the circuit board, failed miserably, broke the shaft on the motor. There are several threads that talk about turning the needle counter clockwise to spin it off. I am still looking for a tach for a 3.2 carrera.
Old 06-09-2018, 05:26 PM
bcgreen's Avatar
I am wondering if it is true in my case to just turning the needle counter clockwise?
68 Shelby 500KR
78 Ferrrari 308
16 Macan S
11 Speedster
Old 06-09-2018, 05:35 PM
Be very careful. A good friend tried to do mine. He had done 15 or so before, no issue. The needle shaft snapped on mine, $400 to fix (with a new motor). Would ahve cost me less to just send it to a show for its repairs. We were just trying to replace teh gears for the odometer.
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 06-09-2018, 07:17 PM
What I did
Searched the forum and found nothing. My needle was very tight, tried the previously discussed methods with no success so I made this with a piece of 1" square tubing and a 10-32 machine screw. Worked great.
1973.5 911T ——-1974 914/1.8
Old 02-04-2020, 03:21 PM
Thanks for the puller photo, I’ll make one today
-Wade
1972 Targa, nothing matching.
Looking for motor 6124265 and transmission 7720299
Old 08-15-2021, 03:21 AM
I’ve seen the needle and the damage done.
Old 08-15-2021, 03:52 AM
wareaglescott's Avatar
I changed the face on my Tach and removed the needle. Not sure if it would be the same. Just rotated and pulled very carefully. Worked out fine. Possibly just more luck than any proper technique or skill!!
Old 08-15-2021, 06:18 AM
you can use a clock hand puller: https://www.jewelerssupplies.com/clock-hand-remover-240.580.html
Old 08-15-2021, 07:01 AM
The rotating counter clockwise and very gentle upwards pressure worked like a charm for me.
-Jayson
1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85)
IG: Signature_911
Old 08-15-2021, 03:33 PM
I used a fork
Pendulum Outlaw, Build, Adventures and Misadventures
Outlaw .... by definition ..... does not follow rules well
www.FloydDesign.ca
https://www.youtube.com/watch?v=sV5aIALWlG8
Old 08-15-2021, 03:59 PM
Tach and speedo
Just send it to jbell959. He did my tach and speedo.
Old 08-15-2021, 04:25 PM
This^^^
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband
Wevo shifter, LSD. Next up, Cams, Heads and port work
Old 08-15-2021, 04:58 PM
GG Allin's Avatar
I used the method in this video. No issues. Start the video at around 5 minutes 30 seconds.
https://youtu.be/pvm23fMcSEA
1988 911 - 3.6
1999 SL500 - Gone
1995 M3 - LS2 - Gone
1993 RS America - Gone
Old 08-15-2021, 05:03 PM
I got a new used tach. Now i will try the odometer repair!
Old 08-15-2021, 09:03 PM
I just did this weekend before last. I thought the key was to do as others said, rotate to the 'stop' in the speedo motor, and push a bit farther while pulling straight up from the center. It won't feel like anything is happening. Then, once you hit the trip odometer reset, go back the other way (towards the high MPHs) and do the same thing in that direction. Back and forth, back and forth, never pulling all that hard, and the needle will come off. Putting it back on is the same procedure but with a very mild downward force.
One thing a lot of older threads would say was "once you remove the needle you have to get your speedo recalibrated". This seemed like hullabaloo to me. Just put a piece of painters tape on either side of where the needle sits before you get started (use the pieces to trace an "outline" of the needle) and use that to align it when you finish. I did so, and also eyeballed my needle about 5mph down since my speedo had been fast by that amount. Ended up 1mph fast at 20 & 40, which is accurate enough for me.
The tape may leave residue, and you will probably leave fingerprints. Simple green (diluted) applied to a microfiber towel worked really well for me. Didn't take anything extra off of the gauge. I applied it, rubbed it very carefully on the problem areas to remove them, and then made sure the excess dried off and the face was clean using compressed air (from my lungs, but a can is probably better). Overall one of the easier and more relaxing things I have had to do on my car so far.
Make sure to take a picture of the wire connections and lights before you remove them, they can be a pain to get back in the right places.
Old 08-16-2021, 08:11 AM
