What are these 2 wires/connectors ?
These are coming from the same harness that houses the power cables for the electric seats.. black/purple and green/black. Both female (or both male, forget which, but both same)
Anyone know what they are for? Thanks 1985 911 coupe drive side only power seat ![]() ![]() |
are you replacing the seat switch? Those two are one on of the motors..unless you have only seat for forward and back these will be for up and down el.motor.from picture i do not see what you have or you did not mentioned ...how many el. motors your seat have?Do you have back rest electrical or manual handle?
Ivan
1985 911 with original 501 645 miles...807 319 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Ok, I had it reupholster... My seat has electric back tilt and bottom raises up and down which are both working . I guess these wires are for the bottom cushion to go back and forth which is manual on my seat.
very likely you have a 4 way switch in 2 way seat.
Tags |
power seat , wire harness , wires |
