-   -   Custom 3.6 harness advice (http://forums.pelicanparts.com/porsche-911-technical-forum/1100404-custom-3-6-harness-advice.html)
MIAdragon 08-20-2021 10:33 AM
Have a 964 3.6 in an old long hood race car that’s going back to street duty. It has the factory harness/ecu but recently picked up a turbo setup and figured an aftermarket ecu would be the route to go. So a motec m600 is on the way and looking for a harness. Ifve seen a few but having a hard time swallowing 5k for a harness, any ideas?
3rd_gear_Ted 08-20-2021 10:42 AM
FYI,
Most Motec shops won't touch the tuning unless they do the harness and integration to the sensors.
winders 08-20-2021 11:13 AM
M600 is probably not the way to go these days....I would look at the new M1 series......I have an M130 in my car and love it.
MIAdragon 08-20-2021 11:19 AM
Picked up the 600 cheap enough can get out of it breaking even. I’ll look at the m130.
TeeJayHoward 08-20-2021 12:51 PM
Build one yourself. The initial tool outlay is a bit pricey if you want the proper milspec stuff, but you can have the final product including tools for less than half of that $5K price tag, AND it'll be built out of better materials than most shops use.
The down side is that you'll be working on it for many, MANY hours.
fanaudical 08-20-2021 05:51 PM
Pelican member Timmy2 builds custom harnesses; you might contact him.
timmy2 08-20-2021 06:47 PM
Nothing for Motec, don’t know the system. Don’t want to tool up and material up for it….
winders 08-20-2021 07:22 PM
You can check with Rasant on the harness:
https://rasantproducts.com
