Parts availability or substitute Q.
Early 911 1967S
What are people doing to replace the intermediate shaft alloy gear. I have zero confidence with machining a set of perfectly good set of aluminium 901/02 cases to accept the later shaft here in Australia. Thanks lyndonhttp://forums.pelicanparts.com/uploa...1629623094.jpg |
Might want to post under the engine rebuild forum and with a title that reflects the part concern
the gear
I have a perfect replacement gear.Size is 0.Comes with the original 3 dowel pins.Ciao Fred
Thanks to all on this site.
I should be able to source a good used one. The 911 will live a bit longer. Thanks Lyndon |
| All times are GMT -8. The time now is 08:54 AM. |
