Fixing collapsible-spare valve stem possible?
I've got a leak at the base of my collapsible spare's valve stem. I'm sure it could easily be fixed by removing the tire and removing and reinstalling the valve stem with a new rubber gasket, but you can't remove that tire with conventional tire-removing gear, the factory manual says--"service by factory only."
Any advice? At this point, I'm trying to tighten the valve stem by rotating it clockwise and hoping that what I assume is a nut inside the wheel is taking up some of the slack, but I don't know how much of a fix that's going to be. Stephan
Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster |
Author of "101 Projects"
Bottle of that tire sealant stuff that you spray into the spare? It may be a moot point, as I don't know how you're going to recompress it...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Stuart Williams '65 911 2.0 '68 FIAT 850 Special '71 GT6 ex-Zundapp collector |
Tire sealant will NOT fix this problem. I had a flat, used the spare, but found it would not hold pressure. Tried a can of fix-a-flat, adn THEN discovered the stuff ozzing out under the rotten valve stem seal.
Local [Porsche-expert] tire guy fixed it like new. Removed the valve to fully compress the spare - no problem.
Tony K '89 944T 944 SuperCup Champ 2004 & 2005 '85 Carrera - Sold [sob] TrackVision 944Cup The 999 Site |
