I hate you guys. I recently fell down the MFI rabbit hole after deciding $5k+ for a set of PMO's wasn't worth it to me and if I was going to start with a blank slate rebuild there may be another way. This thread is making me want to go this direction even more.
I've been reading all of Jeff Higgins old posts and started to put together a spreadsheet of things I need to start accumulating. Henry Schmidt's builds are the stuff dreams are made of and also provide a lot of inspiration. For me EFI isn't even remotely a consideration. One of the things I love most about my car is the lack of computers, having to tune it with a laptop would ruin the experience, I'd rather sell the car. |
Bosch W3DPO, spec for all MFI cars except 911T. Also for 930.
Works in winter or summer, city or highway. |
Thanks Jeff, I'll try that spark plug on my 70 911S
At the end of the day, this is all about having fun. Some of us enjoy discovering how archaic old systems work and trying to make them work for us. I think one thing our little community has learned in these modern times is that MFI is not the mystery some had thought it was. With the benefit of modern instrumentation and test equipment, we can now make these systems run far better than when they were new. To me, that has been the challenge, and the enjoyment. I can see the same satisfaction in getting modern EFI/ITB systems working on these old motors. |
Which ignition are you running? My car uses the old Electromotive crank fire with six split coils, my son's uses the stock distributer (recurved by Barry Hershon) with a Pertronix Ignitor and a Bosch 6AL. Plenty hot spark from both, but they still foul the "fancy" spark plugs. |
Ignition is Bosch 3 pin and Bosch coil from, I think 74-75. I’ve also used the original Permatune blue box and blue coil that Porsche used on 74 CIS 911s when they ran out of Bosch parts in late 73. They seem to perform equally well on this car with no discernible difference.
I am all for people using MFI if that is what they want to do. If I were to pick up a pre 1974 911, I would want one with MFI and I would be happy to deal with the system. If I were building a restomod on a 1974 or later chassis, I would be using EFI.....there is no way I would try to make MFI with the modern engine build I would use. Let's keep in mind that my only point of contention in this thread has been the idea that MFI has superior throttle response to a modern and well setup EFI ITB setup. |
Twisted.... The Electromotive crank fire stuff sucks..... |
So, yeah, 15 years of real world, hands-on experience with the Electromotive crank fire ignition system, and over 20 with MFI. My opinions are based upon actual experience. There are, of course, other ways to form opinions, some more valid than others. |
I guess it works for street cars....I see failures at the race track way more often than I should considering the limited number of people running them.
If anything, these components lead a much harder life on a street/DE car than on any race car. They see a lot more mileage, a lot more duty cycles, a far broader range of climatic conditions (my car regularly sees, with the changing seasons, anything from bone dry 110 degree Eastern Washington high desert to the snow and ice in single digit temperatures of our Cascade Range to our infamous Pacific Northwest rain). Beyond that, this car gets driven every bit as hard on our local race tracks as any race car. My lap times would put me out in front of our local SOVREN (Society of Vintage Racing Enthusiasts) C/Stock class, wherein our local vintage 911 continent runs. Alas, I am "cheating" - my 3.0 displaces too much for the class (2.4 limit), has newer aluminum cases, and is twin plugged. Oh, and I run "Wide A" calipers on the front, also illegal for the class. Even though it is purely my equipment advantages speaking, I do lap faster than they do... So, I guess I'm unclear on how Electromotive "sucks" (but only on race cars...). Race cars are prissy, pampered pussies compared to cars used on the street. Race cars typically get far more love and attention, they get far, far fewer miles (hours), and get to operate under far more controlled conditions. If someone cannot get Electromotive to work under these conditions, he must be rather inattentive or incompetent. It's a fantastic system. |
Yeah, you are so fast I tremble in my racing shoes....jeez. Oh, doing a few laps at a time at race pace is not the same as running 40 minutes to 90 minutes at race pace..... Here is my crappy MoTec setup not using Electromotive: http://forums.pelicanparts.com/uploa...1605733094.jpg |
I went on to explain why I believe these systems lead a harder life in street car, particularly street/DE cars that do double duty. Essentially, they are faced with the harsher environment of street use, plus the same duty on track as any race car. I guess I'm not sure why you would respond to that with a simple argument from (others') authority, a childish insult, and a flash of your wallet. Do you honestly believe any of that furthered your argument, or answered any of mine? :confused: |
Again, why is it some people on this forum are always trying to pick a fight? It’s tiresome.
Come on, Jeff. Your argument is more fallacious than mine. Just because you have had success with Electromotive does not negate what I have seen at the track or heard from high performance engine designers and builders. Also, my photo was not a flash of my wallet anymore than your lap time comment was a flash of your ego.
I am glad you have Electromotive working for you. But don’t try to suggest that one positive case cancels any and all negative cases. Street engines see a different kind of environment than race engines. Race engines won’t last 100,000 miles….so that argument is flawed too. |
The behavior continues and yet still no answer to my question.
Oh, you mean the part where someone has an opinion that is contrary to another person’s opinion? Oh, you want a forum where no opinions or statements are challenged. Boring….and not at all educational.
Race engines do, indeed, see a different kind of an environment. An environment that is much harder on some mechanical components - rod bearings, valve springs, and that kind of thing. Reciprocating, moving parts. These modern ignitions systems have no moving parts. All they "see" is how many times they are asked to provide a spark. In a race motor, they see no RPM induced loads nor stresses that they do not see in a street motor. In a race motor, they are not exposed to the extreme environmental conditions I noted earlier. Coupled with a fraction of the number of duty cycles on a race vs. street motor, these electrical components actually lead a much easier life on a race car than they do on a street car. They are simply not experiencing systems failure due to the added stresses of racing - there aren't any with these kinds of components. These are all points I made earlier, none of which you were able to address - hence your response. I think you must have some image of everything on a race motor (or race car as a whole) somehow leading a much tougher life, somehow being much more highly stressed, than a similar component on a street car. While that is absolutely true for some components (tires, brakes come to mind) it is absolutely not true for others. Electrical components come to mind, including ignition components. So, yeah, if they are seeing failures on race cars, it's due to faulty installation, neglected maintenance, inattention, or incompetence. And I'll bet the truly competent have chosen not to run it because other systems give them other advantages, like full engine management integration with the EFI system. Not because Electromotive is failure prone. |
| All times are GMT -8. The time now is 06:15 AM. |
